yellow straps on trailer wheels
Discussion in 'Questions To Truckers From The General Public' started by ryan785, Jun 18, 2009.
  1. ryan785
    ryan785 Bobtail Member
    I have noticed a number of truck trailers with yellow straps attached to the lug nuts. one per wheel. what are they for?
    thanks
  3. Crash935
    Crash935 Medium Load Member
    329
    163
    Sep 8, 2007
    Wyoming Mi
    The only thing i can thinkof is that some companys are now running trailers with a air supply to the trailer tires. The primary supply runs through the center of the hub and then you have an air line that goes to each valve stem of the inner and outer tire to keep the tire at the proper air pressure.
  4. Working Class Patriot
    Working Class Patriot Road Train Member
    12,683
    23,164
    Jan 17, 2008
    Wherever and Whenever...
  5. Brickhauler
    Brickhauler Medium Load Member
    411
    142
    Oct 1, 2008
    Elizabeth CO
    Those straps are for in the winter. You can look in the mirror and make sure the wheels are turning and the brakes didn't freeze to the drum when you parked. That way you won't drag the wheels and ruin the tires
    Krautsnest Thanks this.
  6. ryan785
    that makes sense!
    thanks a lot!
  7. TEN4DISPATCH
    TEN4DISPATCH Bobtail Member
    43
    4
    Aug 14, 2007
    BALTIMORE MD
    they are equalizers that balance the psi between the inside and outside tire. The tire on the inside get hotter than the one on the outside and thus creating a higher psi. This also acts as a pressure release valve for the inside tire.
  8. fulgrwnmn
    fulgrwnmn Light Load Member
    276
    54
    Sep 17, 2008
    whitehouse,oh
    i think hes talking about the ones on the lugs, there used to tell us if theres a lug coming loose
  9. Brickhauler
    411
    142
    Oct 1, 2008
    Elizabeth CO
    He's talking about a rubber strap that is attached to a lug nut on the trailer wheel. Its long enough that it sticks out and hangs outside the tire. You can look in the mirror and see it that way you can be sure the brakes released and the wheels are turning. Sometimes the brakes freeze to the drums in the winter and if its slick and they dont release, you can be going down the road with a set of duals not turning. I have seen it happen. Even though the road is slick and icy, its still possible to make some big flat spots on the tires and ruin them.
    The plastic things that go on the lugs to see if they are coming loose look like a pointer, the mechanic lines up all the pointers the same way and if a nut comes loose you can tell at a glance.
  10. fastrax809
    fastrax809 Bobtail Member
    21
    4
    Aug 27, 2009
    spencerville ontario
    you are right brickhauler that is what he is talking about they are not that popular in the south yet but they are being used more and more,they took the place of painting lines on the trailer tires to see if they were turning from years ago but this too onlly works if the person behind the wheel looks out at his mirror sometimes.
  11. justanothercrzytrkdrvr
    justanothercrzytrkdrvr Light Load Member
    172
    49
    Dec 14, 2008
    Fort Worth Tx
