X15 O/O Maintenance - What do you do?
Discussion in 'Ask An Owner Operator' started by bonder45, Sep 27, 2021.
  1. bonder45
    bonder45 Road Train Member
    1,803
    5,445
    Oct 2, 2011
    Williston, ND
    Morning X15 owners.
    Let's talk about what you guys are doing for your maintenance intervals ?
    Are you sticking to the standard plans or going above and beyond when it calls for a DPF cleaning or Valve adjustment? What about shocks ? Lets hear your thoughts.
    Picking up my 2 new trucks tomorrow and looking to put together a plan for standard maintenance and looking for input!
  3. feldsforever
    feldsforever Road Train Member
    1,453
    1,440
    Nov 22, 2019
    I don't have that kind of truck, but I put 8 shocks on and now I need tires.
  4. Magoo1968
    Magoo1968 Road Train Member
    2,017
    5,395
    Mar 18, 2021
    St Malo mb
    Back a few years ago when the isx had camshaft issues many guys got burnt following Cummins valve adjustment schedule because warranty ran out before scheduled adjustment. The guys who cut schedule in half got cams done on warranty. Cummins only cares if schedule is good enough to make it through warranty period and is cheaper for megas who trade anyways.
  5. mitmaks
    mitmaks Road Train Member
    2,543
    2,065
    May 16, 2014
    Exactly. They just need to squeeze 500k out of that engine then its new owners problem
    77fib77 and Magoo1968 Thank this.
  6. Midwest Trucker
    5,871
    21,125
    Aug 31, 2018
    Oil, oil filter, fuel filters, grease every 20 to 25,000 miles
    Air filter every 100,000
    My first X15 I did the DPF bake, and overhead at 300k but it didn’t increase the fuel economy any. Also I ended up having a sensor go bad not long after which made me wonder if the whole thing stayed intact from factory if maybe it wouldn’t have happened.
    I now have 2 others that just broke 300k and I’m going to run them out to 500k and sell. If any lights come on then we’ll address at that point.
    They are amazing motors and the emissions is not bad at all compared to past years. I know people don’t change oil as often as me but I’ve had zero issues with 9 motors now so I’ll keep doing what I’m doing.
    Siinman, 77fib77, Cat sdp and 6 others Thank this.
  7. Midwest Trucker
    5,871
    21,125
    Aug 31, 2018
    Oh, as for shocks I do them every time I change tires. So, about 150k on steers and 250k on drives. I also do an alignment each time as well.
  8. bonder45
    1,803
    5,445
    Oct 2, 2011
    Williston, ND
    Thanks for the advise. I was thinking of changing the oil ever 400-500 hours seeing as most of my work is using a PTO.
    I’ll keep in mind the DEF issue.
    D.Tibbitt Thanks this.
  9. D.Tibbitt
    141,171
    Every 10k to 15k oil change, oil and fuel filters. Air filter every 50 k because i do alot of offroading.. Ive changed all the emissions sensors on it including both nox sensors at 500k. All of the sensors were still painted red so they lasted that long. 620k miles and no problems with the engine and i run it really hard out west.
  10. bonder45
    1,803
    5,445
    Oct 2, 2011
    Williston, ND
    You don’t have a X15 do yeah?
    stwik Thanks this.
  11. Ridgeline
    22,116
    113,354
    The cummins are in the heavy haul trucks so they get oil changes every 15 to 25k after an OA is returned.
    These trucks are regularly maintained by amortization of key parts.
    jason6541 Thanks this.
