X15 cummins shaking
Discussion in 'Ask An Owner Operator' started by HeavyHaulPete2004, Aug 7, 2022.
  1. HeavyHaulPete2004
    HeavyHaulPete2004 Bobtail Member
    12
    7
    Sep 21, 2021
    I have an x15 performance in a 2019 Pete 567. When under load either from a stop or just bumping gears, from around 1200-1400 RPMs the engine is shaking pretty harsh. I have 166K on it. I have videos of this happening but can't upload them here. The company has had it in the shop. Checked and adjusted the timing and I don't know what else was looked at. I've heard of a couple things that could cause it but can't seem to pin point it. Any help would be great. I can send the videos to you just PM me if you will. Thank you
  3. Diesel Dave
    8,520
    23,433
    Jan 20, 2010
    Hesperia, Ca.
    Check the air suspension height. I had a similar vibration after I had a transmission rebuild. The shop checked all the driveline components and was all in order, then they checked the air suspension height and it was 1” lower than normal. It was adjusted and the vibration went away.
    mitmaks, HeavyHaulPete2004 and Coffey Thank this.
  4. 77fib77
    77fib77 Road Train Member
    10,167
    62,764
    Jul 7, 2010
    St Louis
    I had a debt on a front wheel. When I was a company driver. It caused a lot of vibration. At 55 to 60 mile per hour. But yours is rpm specific.
  5. HeavyHaulPete2004
    12
    7
    Sep 21, 2021
    So amazing that this helped the issue. It's still there but no where near as bad. So I have to look deeper into the issue. But thank you
    Midwest Trucker and Diesel Dave Thank this.
  6. Diesel Dave
    8,520
    23,433
    Jan 20, 2010
    Hesperia, Ca.
    Have you checked the U-joints, carrier bearing and another possible culprit could be the slip through part of the driveshafts…….
    HeavyHaulPete2004 Thanks this.
  7. HeavyHaulPete2004
    12
    7
    Sep 21, 2021
    Yes I've looked through all of that. I started this life working on vehicles, so this is driving me crazy. I've looked at all the usual stuff
    Diesel Dave Thanks this.
  8. Short Fuse EOD
    2,745
    8,522
    Jul 29, 2015
    Midwest
    Mine is going back to shop for helicopter sounding knock noise around 1500 rpm. There’s a TSB on it.Fuel pump timing..
    …A performance x15 will shake at 1200 rpm in top gears. Too low rpm to run engine. Efficiency yes, performance no.
    Vampire and HeavyHaulPete2004 Thank this.
  9. HeavyHaulPete2004
    12
    7
    Sep 21, 2021
  10. drivinhome
    drivinhome Light Load Member
    91
    102
    Sep 16, 2009
    Southeastern Mass
    Harmonic balancer. Common problem on the x15
  11. HeavyHaulPete2004
    12
    7
    Sep 21, 2021
    Yes we replaced it. Still shakes.
