Hello, I'm looking at a 2022 579 with 306k on the clock with a X15 and 12 speed auto. I've worked on equipment my whole life and am relatively knowledgeable on these things but I've never had to deal with "high" mileage engines like semi trucks, only farm and construction equipment. so I am wondering what would be some issues I might expect to run into on a '22 Cummins plant. I'm not sure if its an EPA17 or EPA21, I haven't seen any service records yet so I expect that will help, but I'd like to know y'all thoughts on any spare parts or PM I should have, or get done before I get on the road. Thank you
X15 300K mile problems
Discussion in 'Peterbilt Forum' started by pathfinder99, May 18, 2024.
I have a 2023 Cummins with 233k miles and haven’t had one single issue. I change the oil about every 30k Mobil Delvac 10-30 (used to do every 20 but stretching them out now).
Fuel filter (spin on) at oil change time. Davco fuel filter as needed..est every 10k. Grease about every 5k or after a cross country trek.
Grease and Davco filter I do myself. Aside from filters I really don’t carry any spare parts.
My 2021 Cummins I had to replace the turbo speed sensor early on. No other issues in the short time I had it..stolen with 115k on the clock.
Not sure I agree with it but Cummins recommended running the top end at 500k. -
Yea, Cummins does recommend a rebuild at 500K, in my old truck i would fill one of the frame boxes with tools, spare parts like gaskets, 2 injectors, spare fuel lines and stuff like that, never really used them except for the gaskets. just didn't know if anyone else did something similar and knew of any major weakness's in the motor. thank you
If you would need to travel to check the truck out, may just want to ask for a picture of the engine labels.
Searching the net with the VIN number can yield some interesting results, A friendly dealer may also do a search and get you some basic build spec and warranty history. -
If it’s the updated 579 with the narrow grille it should be EPA21. I’d say find out what all has been done under warranty. Also there’s a recall on the shift stalk but no parts are currently available. You might want to find out if the shifter is original or if it’s already been replaced once. The new ones will be an updated design.
pathfinder99 Thanks this. -
AModelCat Thanks this.
I’d do one around 75k ish and than another around 400-500k.
Base line for me is over the road truck. Most over the road trucks average about 50MPH over their life time. I would expect to see about 6000 hours of run time at 300,000 miles. If it's under 6000 hours it would raise flags for me.
Real world steps in at that point in the form of idle hours. I would consider up to 7000 hours not bad if the truck has an APU. Some major carriers give drivers financial incentives to keep idle hours under 20%. Idle hours are kinda hard on the emissions system.
If the truck has a PTO or does not have an APU it would most likely throw that number higher.
My knowledge starts to get vague/falter at that point.
Link to Cummins quick reference service guide:
https://mart.cummins.com/imagelibrary/data/assetfiles/0032935.pdfLong FLD Thanks this.
