X chains on coils
Discussion in 'Flatbed Trucking Forum' started by Gunner75, Jun 30, 2016.
  1. Gunner75
    Gunner75 Road Train Member
    5,701
    9,073
    Mar 17, 2014
    Jackson Center Ohio
    I've seen several individuals say that when crossing chains such as with coils, or securing equipment/vehicles, you should use a pad or protective item between the chains to prevent them from rubbing. At tmc i was never trained to do this, however here at builders our safety director says we're not to use x chains because several guys have been ticketed specifically for this. Now i still use x chains, but for safe measure i put a wool pad in between.
    What's the word on this from you guys here? Is there a specific rule that these dot officials use to issue tickets, or is this a bunch of horse ####?
    Dominick253 Thanks this.
  3. bzinger
    bzinger Road Train Member
    16,593
    65,735
    Dec 10, 2014
    omaha , ne
    Good ? I loaded transformers today and noticed the guy in front of me cross chained ..I didn't see the point but maybe I'm missing something ?
  4. Gunner75
    5,701
    9,073
    Mar 17, 2014
    Jackson Center Ohio
    With coils x chains allow the full wll of the chain, where if you use horse shoe chains you only get 1/2 the wll of the chain. So I'll use 2 sets of x chains vs 1x chain and 2 horse shoe chains. Like my current coil is 27567lbs loaded shotgun, i have 2 x chains, and 2 horse shoe chains for a total of 23500 using g70 5/16 chains.
    Dominick253, Bean Jr. and bzinger Thank this.
  5. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    Shotgun coils, at the risk of repeating, require a certain amount of chain through the eye. X pattern is the way to get it done based on WLL of chain for a given size. It's so important. Lives depend on it.
  6. MrEd
    MrEd Road Train Member
    2,196
    2,836
    Sep 2, 2011
    Winfred, SD
    I dont know if it's bs or not, but I do remember being told that x-chains through coil eyes is illegal and can get you a ticket for doing it. I've known guys who said D.O.T. has looked under their tarps. Otherwise, x-chains shouldn't touch. I have heavy pieced of rubber I put between the chains to keep them off each other. The company I'm with now has had a couple guys have issues at the scalehouse for not having padding between chains. So when possible, we just don't x them tight together.
  7. x1Heavy
    34,017
    42,129
    Mar 5, 2016
    Padding goes between coil and deck, padding goes between chain and coil.
    Chain on chain padding? #### it, if you are in a anal DOT Area, grab some padding and wrap it.
  8. w.h.o
    w.h.o Road Train Member
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    Shotgun coils, X chains, no padding on chain on chain.
    U said tmc taught u that, and I know maverick too. I pad straps with excess straps if it's in the pocket, but I never padded chain.... sounds bs to me
    RERM and Dominick253 Thank this.
  9. x1Heavy
    34,017
    42,129
    Mar 5, 2016
    I never padded chain where they did not make contact with anything or with each other. I stick to the deck, and coil padding.
    To be honest DOT man inspects for working limit of strap and chain versus stamped weight of coil. Once he satisfies himself that there are enough chain and strap on the coil to meet 50% strain limit strength on you are good to go.
    Ive had a policy, throw everything on there. So that our Lord can reach down, pick up the entire truck and trailer with load upside down if he wants, coil will stay on.
    KeithT1967 and MACK E-6 Thank this.
  10. Md420
    Md420 Medium Load Member
    469
    559
    Nov 2, 2015
    Tn
    I think its funny that they raise hell on you flat bed guys when you haul coils. I have drove dry van my entire career and have hauled tons of steel and copper coils with nothing more that 2x4 bracing nailed to the floor
    Blackshack46 and Bean Jr. Thank this.
  11. johndeere4020
    8,522
    119,291
    Jan 1, 2010
    Run this by me again I'm confused. What's a horseshoe chain and why do you only get 1/2 the WLL?
