Wouldnt' 11r22.5 on a trailer on the back axle and a 295/75/22.5 on the front axle.
Discussion in 'Experienced Truckers' Advice' started by nhramember, Jan 31, 2013.
  1. nhramember
    nhramember Light Load Member
    86
    25
    Apr 2, 2012
    I have a question i just picked up this trailer i am purchasing from this guy who let it sit for 3 months. It has bridestone 726 el 11r22.5 on the rear axle on the trailer with 27/32nd of tread.It has bridgestone 295/75/22.5 on the front.Wouldnt the tall rubber on the back cause a wear issue with front axle because the front has to turn a half of a turn before the back moves? IF I was to sell these 11r22.5 drives would they be worth 250 a piece? thanks for your time in advance.
  3. PST
    PST Light Load Member
    125
    53
    Sep 7, 2009
    USA
    Would likely ware out the newer tires faster but not fast enough to justify the cost of replacing them, you will however need to match tire size and tread depth per axle side to get the most out of the tires. It's also illegal to mismatch tire size per axle side. Virgin tires that deep and that cheep you would have no problem selling around here.
  4. Les2
    Les2 Road Train Member
    5,150
    2,288
    Jul 25, 2008
    kicked back in my lazyboy...
    Where is it illegal to mismatch tire size..?
  5. thedrifter
    thedrifter Medium Load Member
    522
    263
    May 23, 2010
    portland or.
    Where do you people come up with some of this stuff. If you are repeating what you have heard at a truck stop. You might want to verify before you repeat it. These kinds of comments make you out to be dumber than not saying anything
  6. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    reminds me of the commercial of it must be true, I read it on the internet.
    Les2 Thanks this.
  7. rank
    rank Road Train Member
    9,916
    113,498
    Feb 11, 2010
    This should be docked. :)
  8. rainny
    rainny Bobtail Member
    13
    Jan 31, 2013
    don't know if it's a dot regulation but it's defenitly a safety regulation.
    try to get your rig safety inspected in utah with mismatched tires sizes on the same axle and you won't pass.
  9. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,044
    May 13, 2011
    Middle Tennessee
    What's it matter on the trailer? <-- rhetorical question
  10. blanco
    blanco Road Train Member
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
    Steers maybe, or do u mean tall anf lowpro on same tandem side. Yeah, that wont work.
