When i see a tractor being towed, either by a wrecker or in decked operations the axles of any rear wheels touching the ground are removed. i understand why this is done ( i think?).
But i'm wondering, and let's assume we are talking about a single axle tractor for now, would it be possible to tow by simply leaving the transmission in neutral?
Would it be possible to tow a tractor in neutral?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Powell-Peralta, Aug 17, 2011.
Page 1 of 3
A huge NO!
I Towed trucks for years.
The drive shaft or axle must be removed to keep the tranny from turning.
I have seen them literally explode in as little as 1 mile.zebcohobo and The Challenger Thank this. -
It is possible to tow any vehicle. the problem lays in stopping said vehicles.
The problem is if u do not disconnect either the driveshaft or the axles you are turning the transmition and without the engine running there is no lubrication going to the back bearing and will shortly destroy it.
i.c.; So truck transmission are different from car/ light truck transmissions?
the usual problem is that transmission is not lubricated well and it is not enought, drivers shift range lever down and tow truck. and countershaft spins very fast and as result transmission is ruined inside.
So if you wanna tow a mile ore a bit more - shift range lever up (if there is air in system), if more - disconnect DS. It is not so difficult.
About brakes - tow truck with solid connection, like towing bar ore dolly axe, not on cabel and be carefull -
Probably why when ever my truck was towed (Western Express) they lifted the drives.
Also trucks will be towed from the rear. Just towing a tractor with the right equipment doesn't require any extra braking, but when town loaded straight dump trucks or cement trucks a brake buddy is used, or towing a tractor trailer combo the tow truck will run a supply and service air line to the trailer. When I was towing if we towed anything from the front any further than pulling it out from under the trailer the drive shaft or axle came out.
10_4 the differential must be removed on a 2 axle.I towed a truck from New Mexico to Cali i proped the drives on 6"blocks dumped the air and chained it tight then aired the bags up and stuck 6" wood blocks on the rear between frame and axle and dropped the air and chained it tight the rear axle was a tag axle so it didnt have a differential so it made it easy.If it would've been a working axle do you still remove the differential or as long as the axle lock is off is ok?Nice thread by the way.
American-Trucker Thanks this.
Page 1 of 3
