Worn shift tower?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Lazer, Nov 6, 2020.
  1. Lazer
    Lazer Road Train Member
    1,728
    2,725
    Jan 22, 2017
    2003 Freightliner Columbia, w/ MB engine, Eaton Roadranger 6-10. Gear position 4/9 does not go in gear. I can feel the gear there, but shifter will not stay in.
    How do I test to determine if it is a worn shifter or an actual gear problem?
    All other gear positions work perfectly.
  3. wore out
    wore out Numbered Classic
    15,319
    184,959
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    You can almost bet it's in the transmission. Riding down the road in 10th with your hand on the shifter creates wear on the 4/9 side of the shift collar. Eventually it gets enough wear it can no longer engage all the way. Not saying you do that but its obvious some one has
    Diesel Dave, Goodysnap and AModelCat Thank this.
  4. Lazer
    1,728
    2,725
    Jan 22, 2017
    That possible, this is a company truck, I have been here just over 2 months, everyone that is here says this truck has been this way for awhile.
  5. Hulld
    Hulld Road Train Member
    2,882
    6,564
    Oct 19, 2015
    Upstate NY
    I have seen this problem on Columbia’s before.
    The ones that I have seen with this problem have a piece coming off the stem of the shifter coming out of the shift tower and then the shifter bolts to that.
    This piece is A tapered fit held with a bolt.
    Sometimes this piece moves and doesn’t allow the shifter to fully engage the gear before the shifter contacts the floor board under the rubber boot.
  6. little cat 500
    2,044
    1,090
    Jan 17, 2010
    Abbottstown PA
    more than likely the sliding gear is wore out or shift fork may be bent
  7. Hulld
    2,882
    6,564
    Oct 19, 2015
    Upstate NY
    here’s a picture of a Columbia set up to help you understand what I am talking about.
    Columbia’s don’t have the shifter bolted directly to the stub shaft coming out of the shift tower like most trucks do.
  8. Lazer
    1,728
    2,725
    Jan 22, 2017
    Had a chance to take a closer look today, the shifter in this Columbia is not a straight stick as in the pic.
    This one has a ‘dog leg’ design, towards the driver. Huge boot, after it drops under the floor the shifter is curved forward toward the shift tower, then bolted on a ‘sleeve’, then that sleeve bolts to the shift tower. No slop, plenty of room, shifter never comes close to bumping opening in floor, or dash. Problem must be internal, o well.
