Worn s cam bushings
Discussion in 'Freightliner Forum' started by Motto, May 15, 2020.
  1. Motto
    Motto Light Load Member
    102
    126
    Apr 10, 2020
    is it possible to replace worn s cam bushings on Cascadia without removing hubs ?
  3. AModelCat
    154,534
    Nope. You'll have to pull the hubs. I haven't yet come across any class 8 truck or trailer where its possible to do it with the hubs on.
  4. jamespmack
    213,523
    You shouldn't say that. Lots of trailers come right apart, some even have material removed from hub. Alot with the bolt in outter (wheel end) cam bushing when jacked up and the right angle on the dangle slide right out.
    I can't think of a drive axle off hand. But not gonna say it's not possible.
    stillwurkin Thanks this.
  5. AModelCat
    154,534
    Definitely interesting to hear. I've never come across anything like that before. Then again anything I've ever touched has been bush spec logging, oilfield, lowbed etc.
    Shawn2130 Thanks this.
  6. SmallPackage
    5,278
    16,471
    Dec 20, 2019
    Marion Texas
    On some of the old White spec Rockwell built SQHD’s from the late 50’s-70’s had the s-cam bushing in a “clamshell” that bolted to the axle housing kinda like on some trailer axles. It could be removed without removing the hub or the drum. Maybe even the tires if enough room. You could wedge prybars to keep the shoes in place. They seemed to always be worn out either due to that design or the fact that those trucks were always beat to a pulp in the oilfields and construction.
    Of coarse that is only history and doesn’t answer your question.
  7. Motto
    102
    126
    Apr 10, 2020
    I changed my trailer's bushing tubes yesterday. Just removed the slack adjuster and pulled the tube...
    Now i am thinking to replace truck's bushings without removing the hub.
  8. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    I have noticed some trailers that appeared to have a short s-cam. The maxi was mounted over close to the hub. They may pull out. Never had one apart though.
  9. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    Yes it's possible.
    1 Cage air chamber
    2 Wheels off, drum off
    3 Disconnect and remove slack adjuster
    4 Unbolt air chamber from bracket
    5 Unbolt bracket from axle.
    6 Replace bushings and seals or use new bracket.
    7 Put everything back in opposite order.
    8 Uncage air chamber
    9 Adjust brakes
    10 Drink beer.
    RoadRanger^^ and Motto Thank this.
  10. RoadRanger^^
    RoadRanger^^ Light Load Member
    265
    105
    Apr 17, 2018
    Columbus, OH
    Do you think this also applies for a Volvo truck ?
  11. RoadRanger^^
    265
    105
    Apr 17, 2018
    Columbus, OH
    Three of my trailers actually you can replace the s cam and the s cam bushings without removing the wheel hub. They all use tube bushing hendrickson s28890
