My truck has a tendency to slowly "wander" for lack of a better term to one side or the other requiring a correction usually 1.5-2" from center of steering wheel to get it going straight again. I have examined the entire linkage carefully while rotating the steering shaft back and forth (both with engine running, and stopped). There is no one area which has enough play to cause the wander. Spline shaft from column-good, u-joint-recently replaced and good, steering box, recently replaced-good., pitman arm, tight on output shaft-good. Tie rods and drag link all good. There does seem to be a little bit of slop happening in the king pins. Therefore my question, if the king pins and bushings are worn out, could this cause the steering wander? Note, steering tires do not wear unevenly , no cutting, cupping, etc.
Worn king pins=steering wander?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 04 LowMax, Jul 31, 2015.
Page 1 of 4
Never mind didn't read the whole post.
Steering gear adjustment will make it wonder
you also mentioned king pin slop, I had a KW once that I finally got rid of as it had too much play in the king pin area, trailer was always swinging out.
I do not believe some king pin slop will cause that. I have too many customer claim their trucks drove just fine with badly worn king pins. Some tires can aggressively catch ruts and grooves formed in road surface deformations caused from vehicle traffic and soft road bed. You know those slight dips in the road from where the wheels pass over day in and day out to form those deformations? That is what I mean. Also, some tires seem to really catch the crown of the road and get "sucked" down the other side. It can take 2" or more of steering wheel correction before the trucks responds and counters those dips.
BoxCarKidd, beltrans, GrapeApe and 2 others Thank this. -
The only way I could see a king pin / 5th wheel causing problems if it's dry, or run dry and is all galled up. Sometimes steer tires make all the difference.
Oops meant to reply to end hatred lady. -
Most common cause of what you describe is incorrect toe in but yes that causes tire wear. Check tie rod ends, on crossbar between tires, for up and down play with a pry bar or c-clap. More than 3/16 to a 1/4 is excessive and may not be seen rotating the wheel back and forth. Insufficient caster and extremely worn front spring pins can also cause this. Jack up the front end and be sure the steering turns freely, engine off.
04 LowMax Thanks this. -
Thanks to all replies so far. And, so far, it doesn't seem that anyone is of the opinion that worn king pins (the ones on the steering axle not the trailer) will cause steering wander.Heavyd Thanks this. -
Reason for edit: more info
Page 1 of 4
