Wood grain dash for a Freightliner Columbia...................
Discussion in 'Freightliner Forum' started by Mr. Cob, Jan 13, 2015.
  1. Mr. Cob
    Mr. Cob Light Load Member
    Howdy All,
    My 2002 Columbia, has what is to me a very ugly dash, its a gray and black combination of some sort. I have looked through every custom truck web site I can find looking for a wood grain dash or vinyl decal type thing that could be applied to the stock dash and haven't been able to find anything for a Freightliner. This is one of those things a person doesn't need, I just want it, can anyone point me to a web site or shop that sells such an item? Just tryin to spruce up my truck a bit. Thanks.
    Dave
  3. Freightlinerbob
    Freightlinerbob Road Train Member
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    You could just apply some vinyl like is used on signs. Color match it to your cab color.
  4. Fajo
    Fajo The Dark Knight
    2,214
    2,352
    Jan 26, 2013
    Boise, ID
    That's going to be something that's going to have to be custom done for your truck. You also have to figure out how long you plan to run that truck to figure out if its worth money to change the inside of it.
    You can also check Simi salvage yards and see if you can find one that is around your year (with the upgraded Package) and just change the sucker out for cheaper then it would be to skin the dash.
  5. dustinbrock
    dustinbrock Road Train Member
    1,308
    901
    Apr 19, 2012
    North Battleford, SK
    I saw a guy with a 1926 show car and he had what appeared to be a custom wood grain dash. He said nope, he just painted it himself, said he Googled how to do custom painted wood grain and watched a bunch of videos and went to town....... it looked amazing.
    Could get a carbon fiber done on it but the other options cheaper.
    OR
    http://www.topvinylfilms.com/wood-grain-wrap-vinyl/
  6. The Admiral
    The Admiral Heavy Load Member
    894
    561
    Jul 18, 2010
    Akron,Ohio
    Rockwood may be able to fix you up. I know some of the Classics had a real wood dash as a factory option.
  7. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,995
    Aug 9, 2014
    Merrimack, NH
    Any woodworker can make you a replacement. I am and it's easy. The hard part is taking ALL the gauges out and marking which wires go where and there are A LOT. It's not an easy or fun job. I could make oak, cherry or whatever wood I wanted in 1/2 a day to replace all the panels. You would have to take out the old ones as a reference.
  8. Freightlinerbob
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    I replaced all the gauges on the primary panel ( my columbia has the optional individual gauges) it took a couple of hours and was straight forward. They all run on the same harness so I was able to arrange them how I liked.
    The panel is about 3/32" aluminum and while the gauges can accommodate a lager thickness, the dash design can't. It's all designed to bolt together with that 3/32" panel in- underneath the dashboard trim. It's not like an FLD/ Classic dashboard where the panels sit on top with mounting bolts showing.
  9. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    just a idea iv seen peel and stick vinal wood grain at home improvement stores sold as drawer liners. may be a inexpensive solution and if you don't like the end result your not out much.
  10. brandyrose
    brandyrose Bobtail Member
    18
    11
    Jun 19, 2009
    memphis tn
    I went on line for JC Whitney catalogue. It's expensive but the wood grain vynal body wrap is thicker than the drawer liner stuff,and for the curved parts of your dash,you just heat it up and the vynal melts to the curve. I just swiped it with a lighter. I've got a freightliner too and prefer Wood grain to chrome.But woodgrain accessories seem to be for pets or kw,s.
    Skate-Board Thanks this.
  11. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    Makes me glad I got the Signature interior with woodgrain dash as part of my order on my Columbia.
