Wiring for air dump on spread axle.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by slavcha, May 15, 2016.
  1. slavcha
    slavcha Light Load Member
    151
    133
    Oct 17, 2011
    Utica NY
    I need to instal air dump on spread axle trailer. I'm planing on installing another 7 way connector to run wires for dump, and have some extra circuits for future projects like lift for front axle. So my question is there a standard way of wiring it or i just wire it any way as long is it works? Thanks.
  3. blairandgretchen
    13,238
    70,566
    Dec 9, 2011
    South west Missouri
    Don't believe there is a standard - just so long as you keep your diagram handy, you're all good.
    slavcha Thanks this.
  4. mslashbar
    mslashbar Medium Load Member
    599
    802
    Jul 22, 2009
    elizabeth,co
    Pretty simple, you just have to supply power to the valve, all you need is 1 wire.
  5. slavcha
    151
    133
    Oct 17, 2011
    Utica NY
    Yes its all i need is 1 wire, but have to run 7 lol.
  6. Razorwyr
    Razorwyr Road Train Member
    2,284
    2,824
    Jul 27, 2010
    Meridian, Mississippi
    Why do you have to run 7? You can run 1 into a 7 way
  7. AModelCat
    154,582
    Why not use a 4 pin round plug? We use them all the time for trailer on board scales. Only have to run 4 wires that way.
  8. Ruthless
    Ruthless Road Train Member
    8,803
    86,235
    Aug 28, 2010
    The City.
    Wonder if you could battery power it with one if them chunky car batteries and a remote control. That'd be cooler than cool.
    Beep/pssshhhhh
  9. gunner76
    gunner76 Medium Load Member
    500
    137
    Mar 11, 2010
    IA
    back in the days when ABS first started coming out I had a tractor that had two 7 way plugs ins on the back of the sleeper, one for switched power to the center port on the pigtail and one for constant power to run ABS. I had a spread axle that didn't have ABS so I hooked the dump valve to the center port and ran the dump from the switch on the dash. It was a quick way to dump 700lbs off the tractor if a situation arose that called for it.;)
  10. slavcha
    151
    133
    Oct 17, 2011
    Utica NY
    I don't know exact wiring schematic for 7 way, but i think clearance and tail lights are on separate circuits, and combining them in to 1 will free one wire for a dump. Any thoughts on it?
  11. Luwi67
    Luwi67 Heavy Load Member
    746
    484
    Oct 24, 2012
    Long island
    My dump valve is on a separate 7-pin and it's just 1 wire for the dump valve for the past 13 years. Why run seven wires, that is an extra 300 feet of wire, am I missing something.
