Wiring diagram please for a 2010 KW t800
Discussion in 'Kenworth Forum' started by Cpq28g72, Aug 31, 2021.
  1. Cpq28g72
    Cpq28g72 Bobtail Member
    I have a 2010 KW t800
    AC compressor will only run if I jumper ac relay. So I'm trying to figure out why ac relay gets turned on from.
    Just fixed a Oring leak, fully charged both high and low pressure switches are made.
    Just something causing ac clutch relay not to cycle.
    Thanks
  3. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
  4. kwcam
    kwcam Light Load Member
    193
    145
    Dec 29, 2012
    at the shop
    This might help, sounds like your low side switch control (relay ground ) that runs through the pressure switches and freeze switch is not working, try jumping one or the other pressure switches at the heater box area, easiest to test first.
