I run through Montana, UT, WY, ID, CO, WA etc.. and want to make sure my truck and trailer are ready for the conditions out there
What needs to be done to the truck and trailer to make it ready for winter use?
winterizing
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Stroked F550, Oct 13, 2009.
anyone want to chime in?
Hmmm, lets see...well the way we winterize our trucks up here is going to be way overkill for you, I would say check your anti-freeze and make sure it's good to 40-50 below. Keep a bottle or two of air line anti-freeze in the truck in case you get ice in the air lines of the trailer. Maybe get a winter front(grille cover) for the truck if you think you might drive in temps below zero, also check to see if your factory block heater is working in case you have to shut the truck off for a length of time in the cold.
I'm not familiar with trucking down in those states so hopefully someone who is will give there 2 cents, those are just a couple basic things I could think of real quick...and they still might be overkill for down there.
Oh yeah, chains...make sure you have 2 sets, that there the right size for your truck, and most important you know how to put them onStroked F550 Thanks this. -
I like overkill what ever they do to the trucks up north please share
I would replace belts/hoses and figure out if your coolant is still good for sub-zero weather. Synthetic oil in the engine/trans/rear ends is much better than regular oil in sub-zero temps. I would grease your fittings just prior to actual cold weather. Carry air-line de-freezer. When parking, don't set your trailer brakes/tractor brakes. Be careful on this, make sure you're on level ground, put trans in gear, use a couple 4x4's to block the tires. Even then, be in your comfort zone. If idling, you can't leave it in gear. Fuel additives to keep from gelling are a must, but with ULSD, some are worthless, so I hear. Replace your wiper blades also. Carry can goods in the truck, mittens are good for driving as opposed to work gloves. DO NOT park on a slope, cause you may not have traction in the morning.
in any sub-zero weather theres no such thing as overkill i do the same as above i even have fuel tank heaters for winters i live in wyoming so i know sometimes we see-40 with a nice cool 25-30 mph wind as far as wheel chocks i have taken 1/2 rubber belts and cut into triangles sandwich between steel plates with jagged edge cut into so i can park ,idle , and feel safe sitting doing so . there is also a air line injector that injects airline antifreeze right behind the air dryer in small amounts cost about $80 alot of tankers that have alot of air fittings and valves and swicthes use them. again its all up to what you want to spend $$$$ i even heard of guys tearing entire interior out then re-insulating all walls and floors and ceilings
set your tractor brakes...but not the trailer
anyone who doesnt set any brakes is a moron....try to park facing down hill
the newer trucks dont require a winter front, but one is handy in sub zero temps
park with the grill outta the wind and idle it up to stay warm
need one set of triple rail chains, and two sets of single in the northwest past oct 15
carry spare fuel filters, and a spare belt
if parking on fresh snow pull forward and back a few times to pack it down and prevent being frozen in your spot
carry some food and water in the truck in case you get snowed in somewhere
also grease the truck, check the antifreeze and defroster
and dont drive faster than conditions allow, expect ice everywhere
use a fuel treatment....i like howe's but the other stuff will work tooLast edited: Oct 19, 2009
thanks guys for the info
