winter front grill cover
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mitmaks, Nov 14, 2016.
  1. mitmaks
    mitmaks Road Train Member
    2,542
    2,064
    May 16, 2014
    Anyone running one on their truck, is it worth putting it on to get better fuel mpg in winter?
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    Really don't need one on the new epa engines. Or any engine for that matter. Unless it is subzero weather. And I would only close it off when sitting in subzero weather. Never going down the road.
  4. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    The new ones can't be closed off...
    Do you need it, probably not but it makes me feel better...:)
    Coffey, mitmaks, bzinger and 1 other person Thank this.
  5. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    As long as your truck operates in its "normal" range, it is unnecessary. One should only be considered if your engine struggles to maintain proper temps. If you run one unnecessarily, it may cause overheating issues, so keep an eye on your temp gauge. Personally, I've never had a truck that needed one.
    flood Thanks this.
  6. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    I've never driven a Mack with heat.....
    It's a little joke....:)
    Oxbow and D.Tibbitt Thank this.
  7. Ruthless
    Ruthless Road Train Member
    8,786
    85,952
    Aug 28, 2010
    The City.
    If my grille gets 50% clogged with snow she starts getting hot if not at highway speed. Can't imagine if I put a front on that she would do much but start cookin
  8. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    Your to pessiristic....:)
  9. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    Let try it again.....
    Light - med snow...
    D.Tibbitt Thanks this.
  10. Yves kanevil
    Yves kanevil Medium Load Member
    522
    465
    Jan 10, 2016
    Nighthawk
    -20 or colder I put them on. On our -40 days you really appreciate them
  11. mitmaks
    2,542
    2,064
    May 16, 2014
    I was thinking more when Im in MN, ND, WY with temps in single digits during daytime and windchills -10 -20s
