Winter Driving Tips For New CDL Drivers
Discussion in 'Questions From New Drivers' started by Denbo10, Nov 13, 2024.
  1. Denbo10
    Denbo10 Bobtail Member
    6
    Nov 13, 2024
    This has probably been asked a bunch but what are your winter driving tips especially going over steep mountain passes in the snow?( I have this weird irrational fear of the trailer just taking off on me with barely any braking) kinda weird right? I would love to hear some tips though!
    nextgentrucker, bryan21384 and Kyle G. Thank this.
  3. Moosetek13
    Moosetek13 Road Train Member
    14,519
    17,975
    Nov 1, 2010
    Burnsville, MN
    That is not an irrational fear.
    Never lose your fear in this job. No fear means dead soon.
  4. Denbo10
    6
    Nov 13, 2024
    That’s true! I’d like to be a bit more calm though!
    nextgentrucker Thanks this.
  5. Moosetek13
    14,519
    17,975
    Nov 1, 2010
    Burnsville, MN
    The calmness will come with experience. Just be aware enough to not let yourself get too calm, as in complacent.
    From what I have heard the most accidents happen in a drivers first year, and then again at around the 5th or so year because they get too confident and complacent.
  6. Denbo10
    6
    Nov 13, 2024
    That’s actually really good to know! Thank you, today was my first day chaining up in a snow storm… it was an experience
    tscottme and dosgatos Thank this.
  7. dptrucker
    dptrucker Road Train Member
    4,671
    3,181
    May 14, 2012
    adelanto,ca.
    slow down. speed is your enemy.
    watch your following distance.
    carry a couple gallons of non freezing windsheild fluids.
  8. Moosetek13
    14,519
    17,975
    Nov 1, 2010
    Burnsville, MN
    I also suggest using Rain-X on all the windows and mirrors.
    It really helps with the snow and ice buildup.
    If you want to avoid the effort of applying it correctly on the windshield, which can be a real PITA with those big windshields, they have additives for the washer fluid that help. They get maybe 50-60% effectiveness of applying it by hand, but it does help a lot.
    Walmart carries it.
  9. Pepper24
    Pepper24 Road Train Member
    2,048
    1,558
    Dec 3, 2010
    I don’t know where some truck drivers come up with always be afraid.Where they even come up with all this fear advice I don’t know how they even come out of the house or let go of there mothers hand.As far as driving in the snow there’s no magic answer it’s experience other then slow down keep your distance from others and if you think it’s better to park and let the road crew clean the roads do it.Being prepared like mentioned of proper wipers keeping washer fluid top off drain your air tanks on truck and trailer every day carry a bag of oil dry or salt if you can
  10. Lennythedriver
    Lennythedriver Road Train Member
    2,203
    7,297
    Feb 14, 2020
    SLOW, steady, no sudden maneuvers, snow usually (not always if its atop wet ice)!gives you more traction than ice, don’t slam brakes on, use them gently. If you suspect black ice, always assume there is, eyes way way ahead because guaranteed there’ll be one freaked out driver ahead of you causing something you’ll want to have plenty of time to adjust to, constantly looking for your way out, don’t get in close with everyone else, try and keep lots of separation.
    I drove in the snow in the ice for 30 years in Alaska, but it wasn’t in a semi truck, however, you kind of just developed a nose for it. Wet ice is the worst. Snow isn’t necessarily that bad, if it’s not atop ice.
  11. 201
    201 Road Train Member
    12,044
    24,581
    Apr 16, 2014
    high plains colorado
    Drive like you have an egg between your foot and the pedals. Braking is by far the most overlooked. Don't let schedules dictate your driving. It's a lot easier being late than explaining an accident. A rule of thumb us old timers held, was if you see spray coming up from the tires, probably okay, but if the spray stops, it's ice, and whatever you do, DON'T try to drive on it.Pull it off right then, and not just on the shoulder either, if you can. Someone is bound to slam into you. A ramp is still best even if illegal.
