Well sad to say,but winter is around the corner. What diesel additive do you guys use from diesel gelling in cold weather? Thanks.
Winter Diesel additive recommendations?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by lwlevens, Oct 21, 2018.
Page 1 of 6
I use howels. No particular reasons just habit. However I use fppf. For algae. They make a good anti gel treatment to .
Sorry for the thread hijack.
But if it gets cold enough in an area to gel summer diesel, do the stations not switch to winter blend diesel? -
Fueled in Texas, going to north Dakota! January 27 I'm going to treat with something
At our DC they just dump gallons of
When they dump the tanker. We never have issues.Rideandrepair Thanks this. -
Thanks, now does it matter if I pour that or an other additive in the fuel tank and don't run the truck to much my season ends the end of Nov? But will start the truck occasionally. Thanks.
When I lived in Michigan I used Power Service products as well. Never had an issue with gelling fuel.
The best stuff I have ever found is isopropyl alcohol (also known as rubbing-alcohol)... 90% or higher. Down to -10 degrees Fahrenheit I use 4 oz for every 100 gallons of diesel, any colder amd I will double that dose. I have never gelled up since switching to this.
It is dirt cheap compared to other diesel treatments, is safe for ALL diesel engines, also works as air-line antifreeze, helps keep windshield washer fluid from gettimg slushy or frozen in spray nozzles, sterilizes wounds, and more.just_sayin, Mooseontheloose and TGUNKEL Thank this. -
Doesn't rubbing alcohol contain water?
Edit: normal rubbimg alcohol is only 70%McMahons Trucking Thanks this.
Page 1 of 6
