Window won't go up
Discussion in 'Ask An Owner Operator' started by JonJon78, Aug 18, 2022.
  1. JonJon78
    JonJon78 Road Train Member
    7,042
    37,582
    Jul 1, 2018
    When I'm driving and push the up button my drivers side window won't go up but, when I'm parked with the truck off and key in on position it rolls up fine with lots of power? All the other buttons work fine including "window down"...
    What could be causing this? Any ideas?
  3. supergreatguy
    supergreatguy Road Train Member
    1,030
    2,895
    Nov 26, 2020
    maybe you got a booger stuck in the button
  4. GYPSY65
    GYPSY65 Road Train Member
    1,956
    5,263
    Nov 16, 2012
    SW FLA
    Just a wild guess
    But have you pulled the panel to see if there’s a loose wire that could be moving while driving?
  5. KrumpledTed
    KrumpledTed Medium Load Member
    485
    1,463
    May 6, 2022
    What year is it? Rain falling into the switches on occasion will corrode the switches eventually. Sometimes the module goes bad but I’ve never done one on a newer Pete so I have no idea where it is or how to replace it. The KW has it all in the door.
  6. JonJon78
    7,042
    37,582
    Jul 1, 2018
    Not yet.
  7. JonJon78
    7,042
    37,582
    Jul 1, 2018
    2020 Peterbilt 389
  8. KrumpledTed
    485
    1,463
    May 6, 2022
    I would lean towards the module wanting to act up, especially if it works fine with the engine off but key on. The multiplexing on these trucks these days is a mistake, a monument to our sins against God.
    Boondock, baha, D.Tibbitt and 2 others Thank this.
  9. 86scotty
    86scotty Road Train Member
    4,376
    11,620
    Aug 27, 2017
    Appalachia
    This ^^^
    Sounds like an ECM bug to me. My truck does it on occasion too, it's one of those unreliable POS Volvos everyone hates though. I cycle the key and it works fine again. Actually mine never completely won't go up, the switch just acts up now and then and it won't do anything, but it's not a bad switch I don't think because I can cycle the key and it will work fine again.
  10. SmallPackage
    5,281
    16,471
    Dec 20, 2019
    Marion Texas
    Some Gm cars are developing this glitch. With engine running and in gear it will not allow window to roll up. Put it in neutral with foot on brake and it does.
    Engine off key on works fine. Some stupid safety default feature I’m sure.
  11. AModelCat
    154,581
    Needs some viagra by the sounds of it.
    I'll see myself out.
