window off track
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 85COE, Oct 23, 2019.
  1. 85COE
    85COE Light Load Member
    242
    505
    Aug 6, 2019
    Columbus, Ohio
    never actually worked on a truck before (was not allowed to as a company driver). have my own truck. 1985 Volvo White COE
    driver window is stuck halfway down, won't go back up. I took the interior vinyl 85% off, and didn't see any way to access the upper half of the track.
    Am I going to have to rip the entire door apart to fix this? or should i just get an entire door to replace it?
  3. Smellfunny
    Smellfunny Road Train Member
    1,446
    969
    Jan 28, 2012
    South Carolina
    It may be the guide track broke loose or the regulator bad. I had a Freightliner come in this past weekend and the guide track had broke loose. I cleaned it good and JB Weld it back in place. No need to buy a door just have someone look at it that is familiar with how it should work.
    Rideandrepair, 85COE and BoxCarKidd Thank this.
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,594
    6,697
    Aug 26, 2014
    Try to fix it as mentioned. I thank they used the same doors on some conventionals. Normally just want the guts and use the same door. It could be something simple.
    Rideandrepair and 85COE Thank this.
  5. Rideandrepair
    17,626
    57,042
    Aug 8, 2015
    Take it apart, trying not to break anything else. Might as well learn now, it won’t be the last time you’ll have a problem with a door. There are some speacialty tools for working on interiors, But screwdrivers, pliers, and a few wrenches and sockets should work. The track or bracket that holds window is probably broken
    BoxCarKidd and 85COE Thank this.
  6. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,084
    Sep 24, 2019
    Raleigh, NC
    Often window tracks just needs some lube. Regulator motors do burn out from time to time.
