Window Mount CB Antenna
Discussion in 'CB Radio Forum' started by BTShepp, Feb 1, 2017.
  1. BTShepp
    BTShepp Blue Demon
    373
    215
    Oct 31, 2015
    Chicago, IL
    Obviously there are plenty of inherent flaws with window mount CB antennas. How do they deal with RF ground? Or do they not require a ground plane like those fiberglass antenna kits with special coax?
  3. Neverready
    Neverready Medium Load Member
    405
    330
    Jul 24, 2014
    Pocomoke City, Md.
    I had a 2 meter glass mount antenna. It would work. Wasn't great. I was told the compostion of the glass and treatments of the glass for UV, or shading could affect performance have seen no tests or comparisons to verify this.
  4. CW Spook
    CW Spook Light Load Member
    That's generally correct. They have a number of issues. First, of course is lack of a ground, which requires an antenna that can be configured as a centered half-wave to be effective. Second, there is always significant signal loss without a direct connection which is only made worse by deep-tinting or the presence of defroster wires. Third, their performance is inversely proportional to wavelength, which is why they work OK at cellular or UHF, somtimes OK at VHF and almost always very poorly at 27-28 MHZ.
  5. Ridgeline
    22,112
    113,286
    I agree except for the deep tinting thing, however there is an issue really with the use of these antennas on Ford products that have instant heat windshields.
  6. BTShepp
    BTShepp Blue Demon
    373
    215
    Oct 31, 2015
    Chicago, IL
    What's the appeal of a window mount CB antenna? A magnet mount is easier to install and remove, plus it performs far better.
  7. Meteorgray
    Meteorgray Heavy Load Member
    754
    597
    Jan 1, 2016
    Some folks with motor homes use them because of nonmetal body construction. But they don't seem to perform very well.
  8. BTShepp
    BTShepp Blue Demon
    373
    215
    Oct 31, 2015
    Chicago, IL
    I know a lot of non-metal motorhomes use no-groundplane kits like those from Firestik.
