Wilson vs East stepdeck tri axle 17.5 tires
Discussion in 'Flatbed Trucking Forum' started by Edjahman, Jun 22, 2022.
  1. Edjahman
    Edjahman Medium Load Member
    648
    444
    Apr 2, 2013
    OK so I've been looking at stepdecks and I was trying to get opinions on Wilson vs East and tri axle and these 17.5 tires.
    Does any of this make a difference or is it really an advantage over regular stepdecks with say a spread?
    Thanks a lot
    I get a lot of very mixed opinions about 17.5. I don't drive fast anyway so that's no big deal.
  3. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    17.5 are ok only if you can afford the name brand tires, if you decide to get the trailer and it has China made tires on it and it's still hot weather you had best keep them in the spare tire rack to get home on only, most of these trailers will haul 10 feet hi. of freight that should pay more than 22.5 wheeled trailers do?
    Edjahman, Chieftains and CAXPT Thank this.
  4. kranky1
    kranky1 Road Train Member
    2,253
    8,850
    Sep 16, 2015
    Ontario, Canada
    How many spare tire racks do you have?Even trying to keep 255/70R 22.5’s on a 12’ spread tridem will drive you out of your mind. The 17.5’s have got to be worse, and a lot more expensive.
    OLDSKOOLERnWV, beastr123 and CAXPT Thank this.
  5. pavrom
    pavrom Road Train Member
    3,162
    7,247
    Apr 29, 2012
    NE illinois
    Not true ... I had michelins since new and they wear out same fast as continental ( decided to try on one axle ) other axle Hancock at almost half the cost lasting same long as top brand . Use them on both trailers . I never drive over 70 - never had issues . If you dont move specific tall freight - i would go with 22.5s
    If you gonna drive - you should be fine with either one . Driver - probably twice shorter life span for everything
  6. kranky1
    2,253
    8,850
    Sep 16, 2015
    Ontario, Canada
    I don’t think a 10’1” would be a lot different than one of our 12’ tridems with lopros on it. They’re just going to destroy tires. I got over throwing rubber at them steady a long time ago. Everything here is spreads, 3 of my tractors even. They have 72” drives.
    cke, OLDSKOOLERnWV, Cat sdp and 2 others Thank this.
  7. Kenny Vader
    Kenny Vader Bobtail Member
    13
    32
    Apr 26, 2022
    Pavrom makes a very good point. The issue I had with my step at the time was the length of the bottom deck. It was a 48 OAL with 10 top and 38FT on bottom. Shippers wanted a longer deck than a lower deck height. Unless a guy is in really solid with brokers or agents that have freight for that lower height it isn't a real benefit. If you haven't already check out Driven Trucking on YouTube.This guy talks about his misery with his 53' Reitnouer step deck with 17.5 tires and loading it on the spot market. In the end, everyone has to do their own thinking and go down their own road.
    cke, Edjahman, Blue jeans and 2 others Thank this.
  8. pavrom
    3,162
    7,247
    Apr 29, 2012
    NE illinois
    I cant complain on mine and i do only spot market . Advantage for me having 53' is partials , i have probably 30% of time leaving Chicago partial or 2 , only 5% of the loads or less needed 122" height .
    cke, 77fib77, Edjahman and 2 others Thank this.
  9. Edjahman
    648
    444
    Apr 2, 2013
    I have been subscribed to Driven for quite some time but I'm going back to review some things because this is a new venture.
    What is your opinion on 19.5 tires. From what I've gathered they are more reliable by a lot.
    Is there much height difference with 17.5 vs 19.5 vs 22.5?
    I've been told that tire size does not necessarily translate 1:1 on load height.
    Thank you
  10. Edjahman
    648
    444
    Apr 2, 2013
    I'm pretty sure I'm going to settle on 19.5 but I'm trying to understand the difference between 17.5 vs 19.5 vs 22.5.
    I've been told that tire size does not necessarily translate 1:1 to load height.
    Thank you
  11. Edjahman
    648
    444
    Apr 2, 2013
    I've heard 53 stepdeck partials are quite lucrative. I'm not sure if that's the case but I don't mind doing extra planning/work.
    Thank you
    Blue jeans and CAXPT Thank this.
