Will frozen water crack a block?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by isaitrujillo8, Nov 14, 2019.
  1. isaitrujillo8
    isaitrujillo8 Bobtail Member
    23
    5
    Oct 30, 2016
    Hello everyone I purchased a freightliner classic with a 500 HP 12.7 Detroit. I let it sit a few days and didn’t change the water out for antifreeze. Cold weather came , and I opened the hood and realized everything was frozen and all the frozen water caused cracks in the hoses radiator etc. What are the chances it damaged the engine block? I’m not too concerned about a headgasket or any of that if someone could tell me if that will crack the block. Thanks.
  3. Tx Countryboy
    Tx Countryboy Road Train Member
    1,968
    4,437
    Sep 18, 2019
    Sometimes it will. Check it over good.
    isaitrujillo8 Thanks this.
  4. Mid-May Trucker
    Mid-May Trucker Road Train Member
    1,118
    2,079
    Oct 23, 2018
    Why would you not use antifreeze
  5. isaitrujillo8
    23
    5
    Oct 30, 2016
    Just bought it and the guy didn’t have any in there. I was going to change radiator but cold came a little early.
  6. Tx Countryboy
    1,968
    4,437
    Sep 18, 2019
    Now you may get to change engine too.
  7. lwlevens
    lwlevens Medium Load Member
    623
    427
    Feb 9, 2018
  8. Working2party
    Working2party Medium Load Member
    608
    729
    Feb 10, 2018
    Kansas
    Sounds like you where planning on overhauling it anyway... depending on how frozen it got, usually it will only push out the soft/frost plugs. So, when you get it pulled into the shop and it’s thawed, pressure test the cooling system. Get the engine to operating temp and test it again. If nothing leaks you’ll be alright. I would test to 20-25psi.
  9. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    Water is an amazing power and freeze expansion will break even the strongest of steel. If it holds water after thaw you might have gotten lucky. Check for mixing fluids and leaks and watch it close for overheats.
  10. lwlevens
    623
    427
    Feb 9, 2018
    How cold did it get???? I've had more water than antifreeze in a pick up truck engine before during the winter and didn't crack the block.
  11. Tx Countryboy
    1,968
    4,437
    Sep 18, 2019
    Seen 3 cracked with just water no antifreeze.
    isaitrujillo8 and tommygun58 Thank this.
