Will an inverter run your battery down overnight?
Discussion in 'Ask An Owner Operator' started by yzman720, Sep 5, 2019.
  1. yzman720
    yzman720 Light Load Member
    57
    11
    Sep 19, 2018
    Have a 2007 9400 international. Going to wire in a 3000w inverter and run a microwave and refrigerator on it. If I don't run the truck overnight and the fridge is running and I use the microwave will it drain the battery by morning? Anyone have any thoughts or experience on it?
  3. flood
    flood Road Train Member
    4,157
    4,020
    Dec 25, 2010
    If the trucks not running and you use the micro it will kill your batteries in less to 5 min. Low voltage alarm will go off in less than 2 min
    Just start the truck when you use the mirco.
    The fridge doesn't use much at all. If you have good batteries the fridge can be on for 24-48 hrs and the truck will still start.. Texas summer more like 24, up north in winter more like 48
    So when you stop cook your food THEN turn the truck off and you'll be fine the next day..
  4. Ridgeline
    22,101
    113,190
  5. yzman720
    57
    11
    Sep 19, 2018
    what about if I dont run the microwave? will just the refrigerator run the battery down by morning if the truck isnt running? I could keep the truck running for the short time I use the microwave
    flood Thanks this.
  6. DieselDrivinDaddy
    DieselDrivinDaddy Light Load Member
    230
    531
    Feb 13, 2016
    Poconos, PA
    I leave my inverter on most nights and weekends when I’m home. Powers a 1.7 cu ft fridge.
    If I’m out of the truck longer than a few days or the fridge is empty, I’ll turn it off.
    Truck will be low on voltage and hard starting if I let it sit all weekend in cold weather. Warmer weather it hasn’t been a problem. Anything over two days sitting is when I’ve had to charge batteries.
    Also my Mack only has three batteries. Your truck may have four. Regardless, I have had no problems letting mine sit overnight with the fridge running.
    jammer910Z and yzman720 Thank this.
  7. Concorde
    Concorde Road Train Member
    4,344
    15,420
    Jun 29, 2016
    West Melbourne Florida
    Consider keeping a spare alternator in your truck and installing a amp gauge.
    Turn your truck off after the amp gauge goes back to zero..
  8. Anywhichwaybutloose
    Anywhichwaybutloose Light Load Member
    157
    263
    Jun 24, 2017
    You could get a voltage gauge that plugs in the cigarette lighter. Run about 10- 15 dollars.
  9. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    run the truck when using the microwave plus a little while after. fridge on the inverter takes about 2 days to drain the battery
    flood Thanks this.
  10. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    You can wire it to 100 batteries all of them will be dead by morning.
    Your inverter will kill the truck in about 4 minutes, if your truck knows the voltage is bleeding fast, it will alarm you in 2 minutes more or less. If you do nothing then you are in a truly dead truck, in addition to now having to replace ALL 4 batteries.
  11. HoneyBadger67
    2,056
    4,511
    Dec 15, 2018
    Savannah, TN
    I hope that's sarcasm....
    jammer910Z Thanks this.
