Wide load mirrors
Discussion in 'Heavy Haul Trucking Forum' started by 07shaker, Jun 10, 2016.
  1. 07shaker
    07shaker Light Load Member
    189
    626
    Jan 12, 2013
    Tx
    Just curious what options are available out there for mirrors for wide loads. My brother and I are setting up several trucks to haul oversize and I know there are some like the mobile home toters have but those are not an option in this case because they are brand new lease trucks. Peterbilt 579. Any suggestions on what would work? The factory mirrors are attached to the door with one plastic arm at the bottom so I am concerned about getting too much weight on there if we go with something that attaches to the factory mirror. It also needs to be something very functional because they will be doing multiple loads per day so they will be used a lot. Thanks for any helpful suggestions!
  3. Oxbow
    Oxbow Road Train Member
    12,798
    132,478
    Nov 24, 2015
    Murray Trailer makes some nice mirror extensions, but I don't know how one would mount them on the 579 mirrors. They are ideal for the older style mirror brackets.
    07shaker Thanks this.
  4. truckdad
    truckdad Road Train Member
    2,029
    16,709
    Dec 14, 2014
    Penn Valley, CA
    I will bet Murray or Cozad have some to fit the new trucks. I have a set in my shop for a 359/379. @Oxbow Need a set???
  5. Oxbow
    12,798
    132,478
    Nov 24, 2015
    on
    I have a set that I got from Murray @truckdad, but thanks.
  6. Slay
    Slay Light Load Member
    131
    134
    Jan 7, 2015
    There is a company that makes wide load mirrors for pickups, maybe 16 ft wide. I bet you could make or have them make the brackets to fit on the fire wall of your truck. It is at least worth a look. Google: "The Trailer Shoppe"
    Oxbow Thanks this.
  7. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
  8. Oxbow
    12,798
    132,478
    Nov 24, 2015
  9. 07shaker
    189
    626
    Jan 12, 2013
    Tx
  10. johndeere4020
    8,522
    119,292
    Jan 1, 2010
    @catalinaflyer had a set on a T680 Kenworth he might be able to give you some insight.
  11. catalinaflyer
    catalinaflyer Road Train Member
    2,278
    Wichita, KS
    Those extensions made from the small round tubing will only work out to about 11-12 wide at most. They are just to light weight to be stable any wider. You can add pieces to make them wider but they will vibrate so bad they are useless. Get a hard gust of wind or some small tree branches etc. and they'll just bend/kink and become junk.
    I will look when I get to the office and see if I can find pictures of the extensions we made for the 680's. They were fabricated from steel plate and 1" square tubing with smaller square to fit inside and bolts to tighten against it to hold it. With just the mirror pieces I could go 13' wide and with the extension tubes out to 18' wide. Beyond that you need 2 pilots anyway so your paying that person behind you $1.65 a mile to be your mirror extensions anyway.
    Oxbow and skootertrashr6 Thank this.
