Wichita, KS to San Antonio, TX
Discussion in 'Questions From New Drivers' started by Scott118, May 8, 2021.
  1. Scott118
    Scott118 Bobtail Member
    May 8, 2021
    Is there a route from Wichita to San Antonio that allows you to avoid Dallas/ Ft. Worth? Drove through there a couple times this week and no matter the time it was crazy.
    truckdriver31 Thanks this.
  3. kemosabi49
    10,438
    44,390
    Jan 13, 2013
    SW Arkansas
    You can run I 35 down to Okie City then run I 44 down to Wichita Falls, Tx. Then U.S. 281 all the way to San Antonio. Miss that mess in Austin that way too. Lot of 2 lane on 281. Be better to time your run to hit Ft Worth in the night hours.
    Running I 35W the Ft Worth is @12 miles shorter than I 35E through Dallas and I have found that it is usually a little faster. Of course, any small screw up will back up traffic there. Even someone changing a flat.
  4. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    you picking up at the tyson plant
  5. Scott118
    May 8, 2021
    No, just a couple of different stops.
  6. spindrift
    spindrift Road Train Member
    3,233
    12,905
    Dec 2, 2014
    Texas
    Excellent routing.
  7. F4T6UY
    F4T6UY Medium Load Member
    567
    1,807
    Oct 24, 2017
    Very South Texas
    Yeah, the 281 route is less of a headache, but more lights/small towns.
    DFW is rarely the problem. It’s Waco to Austin that makes me decide to go 281, lol.
  8. Cobrakaiguy
    Cobrakaiguy Light Load Member
    122
    99
    Nov 16, 2020
    Dallas
    DFW is not that bad, just run through there in the late evening, night or early early morning. Most routes around will have lights or small towns. If you come down 35 you can run 35w to the 820 loop to 20, and F4T6UY is right the Waco to Austin area with all the construction is worse then running through DFW.
    NavigatorWife Thanks this.
  9. PacoTaco
    PacoTaco Medium Load Member
    468
    2,241
    Apr 16, 2016
    South Texas
    To me 35 is the best option. 281 is hilly with lots of small towns.
  10. God prefers Diesels
    4,198
    22,259
    Jun 26, 2020
    South Texas
    Not to mention half of it is under construction. I sit in 6th gear on I-35, maintain about 400' in front of me, and just grit my teeth until I'm through it. You do that, and you can pretty much maintain 15mph the entire time. It's the fastest route.
    NavigatorWife, F4T6UY and PacoTaco Thank this.
  11. Moose1958
    Moose1958 Road Train Member
    15,091
    33,174
    Dec 17, 2010
    Williesburg, Virignia
    Use 35W if at all possible. Driving a CMV through the mixmaster even in non-rush traffic situations is tough! Years ago the Texas DOT fixed the east-west problem by routing I 20 south. Maybe one day they can find a solution to rerouting I 35 E&W.
