Why would the driver side turn signal on the trailer work, but not the passenger side?
Discussion in 'Questions From New Drivers' started by Davidbenjamin, May 10, 2021.
  1. Davidbenjamin
    Davidbenjamin Bobtail Member
    48
    47
    Apr 2, 2020
    Is it because of a bad electrical connection, and if so, how would I fix it? The four way flashers only work on the driver side of the trailer as well, I.e. they only flash on the driver side when I turn them on. The tractor lights work fine.
  3. Arctic_fox
    3,864
    19,461
    Sep 16, 2016
    Check your pigtail pin connection. Look for bent/tarnished/damaged/missing pins or pins with grease on them before anything else. Also check the holes as well to make sure the metal hasn't stripped off for example. Next either get a voltage tester and check the pins are actully giving voltage or replace the pigtail.
    Odds are good that is the problem. If not it may be a blown fuse though thats unlikely if the truck lights work. Otherwise something shorted in the trailer which can be much harder to track down.
  4. God prefers Diesels
    4,198
    22,259
    Jun 26, 2020
    South Texas
    Pull your pigtail and meter it while you run your blinkers. If you have juice, it's in the trailer. If not, it's in the truck. Work your way that direction. But my guess is a loose/busted wire at the pigtail, or corrosion inside of one of the 7-ways.
  5. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,483
    Nov 11, 2008
    Sorrento Maine
    On a freightliner, the right and left are two different circuits.
    Make sure it isnt a blown fuse. If it has a resetable breaker. lightly touch the outside, if it is hot you have a short
  6. Davidbenjamin
    48
    47
    Apr 2, 2020
    I'm back up and running now. All I had to do was spray some wd40 in the pigtail. Thank you all for helping.
  7. kemosabi49
    10,438
    44,388
    Jan 13, 2013
    SW Arkansas
    You should get a tube of Di-electric grease. Put just a dab in each of the holes in your pigtail.
  8. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    Thanks for ck. back in that you got it working, that turn sig. must be working all the time, if you roll up to a DOT insp. and its quit again you will be put out of serv.
  9. Moose1958
    Moose1958 Road Train Member
    15,090
    33,172
    Dec 17, 2010
    Williesburg, Virignia
    There is another quick test I have done many times over the years. If you have been doing pre/post trips you should have confidence in the tractor systems working right. If the tractor's lights are working but the trailer is not AND you have been doing the pre/post trip inspections on the rig in the days before you can be 99% sure it's in the trailer. If I am where I can I will report that trailer and go slide under another one.
  10. skallagrime
    skallagrime Road Train Member
    3,836
    9,880
    Apr 10, 2012
    Indiana
    If all it was was the pigtail, the long term fix is either spread the pins on the trailer pins (if not replacing that socket) or replacing the pigtail end on the tractor
    Both are annoying and it may be cheaper timewise to just buy a new green cord with the ends already done up
  11. God prefers Diesels
    4,198
    22,259
    Jun 26, 2020
    South Texas
    Exactly what I do. Every time I grease the truck, I pull both my pigtails and grease both ends with this stuff. It's also great for O-rings and glad hand gaskets, because the silicon grease doesn't eat rubber/nitrile/viton/ect.
    https://www.amazon.com/Dow-Corning-Ring-Silicone-Lubricant/dp/B08P5RJVLW
    Davidbenjamin Thanks this.
