Why would milk tank trucker's want a short (28') inner bridge length?
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Mike Murphy, Apr 21, 2015.
  1. Mike Murphy
    Mike Murphy Bobtail Member
    34
    42
    Apr 28, 2014
    Hello To All -
    By way of introduction, I am a Research Engineer with the University of Texas - Center for Transportation Research. I have posted questions on the TruckerReport forum before regarding truck size and weight questions when I could not find help anywhere else (and nothing could be found in publication). ;-)
    I am currently working with other researchers to evaluate a proposed Texas State Legislature House Bill (HB 3129) to increase the allowable gross vehicle weight for milk tankers to 90,000 lbs. The bridge and pavement analysis will be straight forward. However, there is a special exemption currently in state statutes that allows a milk tanker to operate with an inner bridge length of 28' or greater (36' is legal in Texas) as long as the trailer and drive tandems are carrying 34,000 lbs each. Likely this would change if the 90,000 lb Bill is passed.
    However, though I have searched all of the literature I could find on the subject and have stopped to talk with Western Dairy Transport operating out of Windthorst Texas - I have not yet been able to find out or understand how a milk tank trucker could benefit from a shorter inner bridge length. It seems this would reduce the capacity of the milk tanker, unless a larger diameter tank was used. Most of the tank trailers I've seen are around 6,000 - 6,400 gallon capacity which would be roughly 51,000 lbs - 55,000 lbs of milk. I haven't seen any milk tank trailers running in Texas that seemed much larger in diameter than the typical tank trailer units (Polar, Tremcar, Burch Tank and Truck, or Paul Mueller for example) or appeared to have a shorter inner bridge length.....though perhaps these are used in certain parts of the state. I don't get to El Paso or Amarillo that often for example..........I think Fresh Dairy Delivery is out of El Paso and WDT is out of Cabool, Mo though I see their trucks all the time on IH 35 in Austin; other milk tankers I've seen Texas Highways over the years are Lone Star Milk Transport, Southern Food Groups (Dallas) Winburn, Leibham, GH Processing (Arizona), Mountain Milk Hauling, Carpenter's Milk Service, and others that escape my mind right now.
    Can you help me understand if a 28' inner bridge exemption is of any use? Is this perhaps an old exemption that made sense decades ago, but is no longer in use though it is still on the books? One of the frustrating aspects of researching these issues is that the history of why certain rules, code or laws were passed is not retained and the people involved have retired long ago.
    Any help you can give will be much appreciated,
    Thanks very much,
    Mike
  3. passingthru69
    Maybe some of the pick up points have a limited turn radius at their site.
    Thus the reason of wanting shorter inner bridge.
    Plus they could just add an extra axle on current trls. and not have to buy all new units.
    Just my thoughts
    heyns57 Thanks this.
  4. Neverready
    Neverready Medium Load Member
    405
    330
    Jul 24, 2014
    Pocomoke City, Md.
    My guess also would be loading out of tight farms and old access roads and driveways with tight turns.
  5. mnmover
    mnmover Road Train Member
    1,237
    1,103
    Apr 5, 2009
    Lichfield MN
    The companies you see on I35 are going usually from plant to plant Or from a very large dairy farm to a plant location. Do any neighboring states have the bridge law for milk haulers? Where I live in Minnesota we have 7 axle straight trucks that's right 7 axles, of which 4 lift, one behind the tandem drive axles and up to 3 in front of the drives with steerable single wheels grossing 80,000. Then we have some 53 foot tankers with 4 axles, 2 axles liftable pulled by a 3 axle tractor running 96000 in Iowa and up to 97000 in MN but not on interstate routes in either state.
  6. mnmover
    1,237
    1,103
    Apr 5, 2009
    Lichfield MN
    One of the best carriers for hauling milk is called Milky Way out in Washington state. The run doubles both trailers tandem axle, and a longer pole on a single axle converter dolly pulled by a day can tandem axle tractor, but they can run 105,500 lbs in WA.
  7. Mike Murphy
    34
    42
    Apr 28, 2014
    mnmover - Thank you very much for your replies. Actually, I am familiar with the Specialized Hauling Vehicle (SHVs) configurations in Minnesota and we considered including a 5-axle straight truck - steer, plus fixed tandem and 2 air liftables. However, milk haulers don't currently run these configurations in Texas and in any case, this unit would not be able to operate at 90,000 lbs.
    The American Association of State Highway and Transportation Officials (AASHTO) Manual on Bridge Evaluation now includes bridge load configurations for SHVs with 4, 5, 6 and 7 axle configurations. Either pusher, tag or booster axles are considered. However, the assumed liftable axle loads are capped at 8,000 lbs per axle which might or might not be the actual weights that are applied depending on how the axles are adjusted.
    It appears that maneuverability is the main reason for the shorter inner bridge length as mentioned by passingthru69 and neverready.
    I've been to Minnesota and Michigan and have seen the caterpillar rigs and other specialized trucks that operate in the 'frozen four' ----- the combination of heavy trucks and harsh winters likely creates very difficult design problems. I've visited the MnRoad project near Albertville on I-94 during its construction ----- this project has really paid off for Minnesota and the nation....lot's has been learned.
    Thanks again for your help. I would appreciate comments from other milk haulers.
    Mike
    MJ1657 and passingthru69 Thank this.
  8. passingthru69
    I like the fact that an engineer asks us about real world issues in these matters.
    Plus he posts the facts and figures they are looking at..
    Keep up the good work sir, even though it looks good on paper it must work. lol
    RockinChair, MJ1657 and KenworthGuyNH Thank this.
  9. MJ1657
    MJ1657 Road Train Member
    7,521
    50,150
    Jan 28, 2012
    Isanti, MN
    Before the days of 7 axle trucks our milkman had a 3 axle truck and pulled a 2 axle spread axle pup. Both of the pups axles were mounted solid.
    When he would make a turn loaded you wanted to run and hide in case something flew apart. Lol
  10. mnmover
    1,237
    1,103
    Apr 5, 2009
    Lichfield MN
    How can these states allow 90,000 since the Federal Freeze in 1991 froze the weight and length limits on states that didn't allow over 80,000 lbs. Iowa, MN MO allow extended weights on Federal and US highways, but not on the Interstate system, the very roads that were designed to allow vehicles up 200,000 lbs? In my opinion, the 1991 freeze that limited weights needs to be repealed. Also allowing a shorter inner bridge violates federal bridge laws. Any truck trailer that runs 90,000 needs the length AND at least 6 (six) axles. I had a tri-axle truck with a 4000 gallon Polar tank in 1977 should have never gotten a tank that larger. Was top heavy. I wanted the lift axle behind the drive axles, but couldn't convince the builder, so my 12,000 lb front axle was carrying 14 to 15000. Had to get the axle re arched every 6 months it helped with 1200x20 tires, was still too much weight....
  11. Hbolser
    Hbolser Bobtail Member
    From my 18 years experience as a milk hauler and my father owning a milk hauling company for 30+ years it is to accommodate tight turns on County Roads and into Farmers driveways off of County Roads that the shorter Bridge makes it possible to do so
