Why won't my fan clutch clutch disengage?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by slick3653, Feb 22, 2014.
  1. slick3653
    slick3653 Bobtail Member
    8
    Pinetown, North Carolina
    I have a 1995 Mack CH613. My fan is running constantly. I have run electrical continuity tests, air tests, and replaced the fan clutch solenoid switch...fan still runs wide open. I removed the air line to the solenoid and replaced it several times and you can hear the fan clutch engage as soon as it gets air. Any ideas?
  3. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    CK. if your air lines might be reversed, take them off change them?
    slick3653 Thanks this.
  4. pop's
    pop's Light Load Member
    54
    16
    Feb 3, 2013
    Yulee FL.
    jump your a/c high press switch.
  5. Jimmbuds
    Jimmbuds Medium Load Member
    398
    179
    Apr 20, 2009
    Daytona Beach, FL
    Just FYI this happens to mine at random intervals. I have narrowed it down to when the engine is cold and moisture seems to find its way into something. What that something is I am not sure, I am assuming it is the clutch. It normally takes 350 to 800 miles to shut off. The last time it happened I got flustered and changed the fan switch and then the clutch. After replacing the clutch it there was no issues. Just something to take into consideration.
  6. slick3653
    8
    Reversed the air lines with no change.
  7. slick3653
    8
    Dumb question, how do I do that?
  8. Jimmbuds
    398
    179
    Apr 20, 2009
    Daytona Beach, FL
    Get you about a 5 inch piece of wire. Unplug the connector from the high pressure switch and put your wire in one side of the connector and the other end of the wire in the other side.
  9. bigdad7
    bigdad7 Road Train Member
    1,837
    1,364
    Jun 6, 2010
    ks
    Make sure some didnt change the fan cletch someone did that on mine we kept putting the wrong soenoid on best way to check this get a universal solinoid and match it to the clutch
  10. slick3653
    8
    Sorry,I meant, where do I find the high pressure switch?
  11. slick3653
    8
    Brain fart...I know what you're saying now. I will try that next. Thx.
