Why/when are a trailer's tandem wheels adjusted?
Discussion in 'Questions From New Drivers' started by Switcher, Nov 22, 2016.
  1. Switcher
    Switcher Light Load Member
    165
    108
    Nov 13, 2016
    Serious question, I'm new to all of this. 28' trailers turn so easily, so what's the point of having adjustable tandems on 53' trailers when the trailer remaining behind the tandems makes it so much easier to hit something when turning?
  3. Numb
    Numb Crusty Curmudgeon
    3,940
    8,771
    Jan 30, 2012
    Charlotte, N.Carolina
    weight restrictions on the axles.
    moving the axles moves the weight,forward or back.
    gdyupgal and Switcher Thank this.
  4. w.h.o
    w.h.o Road Train Member
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    Axle weight limit, bridge law, kingpin law
    But mainly to balance weight. You don't want all the weight on the trailer or drives, but to spread them out evenly
    Toomanybikes and Switcher Thank this.
  5. Moose1958
    Moose1958 Road Train Member
    15,092
    33,183
    Dec 17, 2010
    Williesburg, Virignia
    Xzay, ExOTR, Getsinyourblood and 4 others Thank this.
  6. VIDEODROME
    VIDEODROME Road Train Member
    1,486
    1,296
    Jun 7, 2007
    angola, in
    Mostly to distribute weight.
    If the load is lite, put them where ever. Maybe push them to the middle or front for easier turning.
    Switcher Thanks this.
  7. DustMyBroom
    DustMyBroom Light Load Member
    161
    182
    Oct 11, 2016
    Aside from weight issues, you have a tighter turning radius with them slid all the way up. Slid all the way back makes it easier to estimate where the back end and off side of the trailer is when backing. You will eventually find docks that need all of one and none of the other. In other words, some docks have tight side clearances, but plenty of room to do an alley dock. Slide them all the way back. Others have plenty of room at the sides, but little room in front of you for maneuvering. Slid forward can save you here. Your worst nightmare is tight side clearances combined with a lack of maneuvering room.
    Finally, a lot of shippers prefer tandems slid all the way back. It makes it less likely the forklift will push the trailer away from the dock while loading and unloading.
    Switcher, DRAGON64 and gdyupgal Thank this.
  8. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    Also Forklift has less bounce when tandems are all the way back, a note you never ever drive with tandems full back.
    Regarding the hitting anything, that is where you come in. The Professional. Managing two turning circles, your tractor's and your trailer's that change as necessary. If I recall it's 50 to 70 feet down to zero or minus (When you are pivoting in place by force)
    There is another reason not yet touched upon by the previous posters, Ride quality. A properly placed tandem in either the trailer and or the slidable 5th wheel (Which is not moved very often, keeping the front of trailer equal to or just behind the vertical front of the forward drive tires...) will improve your ride very much, If you were loaded certain heavy on one end of the trailer, it will try to beat you black and blue all the way down the road or handle like a huge anchor from God preventing you from doing anything and possibly even inducing understeer or oversteer etc.
    The holes on the rails on which the tandems rest mean a certain weight usually 250, 500 or 750 pounds each. To slide forward towards drives is to gather weight to slide back from drives is to load the tractor with more.
    There are additional operations possible with trailer when you are in a tight place in addiition to sliding tandems all the way up. You unhook and then approach it from the side very extreme gentleness for it's king pin with your 5th wheel. Once you capture it you can spin it out of there. Minding your ### end so you don't tear into something on the other side of it.
  9. pattyj
    pattyj Road Train Member
    22,474
    20,138
    Jul 19, 2008
    Sioux City,ia
    Like ppl said it's all about the weight each hole on the tandems is anywhere between 250 to 500 lbs depending how far they are spaced apart.You'll learn all this as you go and also ask other drivers for help.
  10. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    To state another way what has been replied ... You're limited to 34k lbs on a dual axle set. Understanding that loads in trailers all vary (with weight distribution), then there needs to be a way to try and counter this to keep weight legal on trailer [and tractor]
    Where the tandems are situated will alter the weight in the trailer, and thereby altering the weight on the tractor.
    Switcher and blairandgretchen Thank this.
  11. Switcher
    165
    108
    Nov 13, 2016
    A ton of info in this thread! Do flatbeds and tankers have adjustable tandems too?
