Why turn pallets sideways?
Discussion in 'Questions From New Drivers' started by Jdm5jdm5, Nov 14, 2019.
  1. Jdm5jdm5
    Jdm5jdm5 Light Load Member
    193
    60
    Apr 13, 2016
    I've picked up at a couple places and they ask if i want the pallets turned sideways. What are the advantages of turning pallets sideways? Do sideway pallets only tip front to back, preventing them from tipping left to right?
    truckdriver31 Thanks this.
  3. VolvoTerry
    VolvoTerry Light Load Member
    293
    377
    Sep 7, 2015
    Based out of Omaha,NE
    Turning pallets sideways will allow you an additional row of freight. Common in refridgerated world. Doing so will also effectively slide more weight forward.
  4. Hotplate
    Hotplate Medium Load Member
    320
    721
    Sep 20, 2015
    Loading pallets sideways saves you space if they're standard 40x48 foot skids. It might not seem like much at first, but it adds up. For a full load to the back door, you'll be able to squeeze in an extra two pallets if they're all side loaded
  5. Jdm5jdm5
    193
    60
    Apr 13, 2016
    If you have a single sideways pallet is it more likely to tip over left to right?
    trkrjim and truckdriver31 Thank this.
  6. Accidental Trucker
    Accidental Trucker Road Train Member
    3,394
    7,531
    Jun 4, 2015
    Three reasons I know of:
    Less movement side to side -- in some areas (Alberta, for example) consider more than about 8" of room side to side an "unsecured load", even in a van.
    On a flat bed or curtain side, if you're going to be off loaded from the ground, the pallets should be sideways.
    If you have a bulky load, turning them sideways gets more pallets on the truck.
    Make that four. It also moves weight forward.
  7. VolvoTerry
    293
    377
    Sep 7, 2015
    Tipping point is mute regardless of which way the pallet is turned. Most pallets tip due to accelleration and or hard braking.
    truckdriver31 and Jdm5jdm5 Thank this.
  8. mitrucker
    mitrucker Road Train Member
    5,402
    9,954
    Dec 15, 2010
    Lapeer, MI
    Or turning too fast
    VolvoTerry, truckdriver31 and Jdm5jdm5 Thank this.
  9. Jdm5jdm5
    193
    60
    Apr 13, 2016
    If you have a single sideways pallet (loaded single, double, single in the nose of the trailer) is it more likely to tip over side to side?
  10. mitrucker
    5,402
    9,954
    Dec 15, 2010
    Lapeer, MI
    No. Less likely to tip side to side.
  11. Moosetek13
    Moosetek13 Road Train Member
    14,811
    18,685
    Nov 1, 2010
    Burnsville, MN
    Wouldn't that be lateral acceleration?
