Why my truck jerks
Discussion in 'Ask An Owner Operator' started by Wajid8705, Aug 31, 2019.
  1. Wajid8705
    Wajid8705 Light Load Member
    66
    40
    Jun 9, 2018
    North Carolina
    It does not happen all the time but lifing foot off accelerator to slow down and then accelerating again the truck jerks.
    Anybody have any ideas to why it does that?
    Thanks in advance.
    stillwurkin Thanks this.
  3. xsetra
    xsetra Road Train Member
    5,092
    6,939
    Aug 21, 2011
    Truck make and model.
    Is it a lag in time from pushing on pedal to actual acceleration?
    Could be your "go" pedal sensor is starting to fail.
    Clean the area under and around your pedal.
    Just a guess. Do you get any codes?
  4. boneebone
    boneebone Road Train Member
    2,294
    2,365
    Mar 13, 2009
    Check pedal position sensor or the accelerator pedal itself.
    Wajid8705 Thanks this.
  5. Wajid8705
    66
    40
    Jun 9, 2018
    North Carolina
    2002 Freightliner Columbia with Detroit 60 Series 12.7
    No lag in time.. I mean when I say jerk this whole truck really shakes lifting foot on and off accelerator I noticed mostly in low gears.
  6. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    You are taking off a huge amount of force from those low range gearing. There is a great deal of multiplication of the power in reduction from your engine turning many times to turn your wheel one time to stop the earth from moving and get your big heavy trailer moving.
    Take your foot away or clutch in shes gonna lean and jerk. The key is to be GENTLE.
    Now if you got the classic pound back and forth thats the 5th wheel being loose with the trailer. Adjust it at the shop.
    Sometimes when you ask a truck to move out in deep low shes gonna lean. Hold on to her and let her do what she needs to do until you are out of that spot.
    Dino soar, Wajid8705 and Iowa80 Thank this.
  7. AModelCat
    154,243
    Check your driveline for excessive rotational play.
    Sons Hero, Oxbow, jamespmack and 7 others Thank this.
  8. FoolsErrand
    FoolsErrand Road Train Member
    2,877
    12,169
    Sep 15, 2017
    Bad slip splines, carrier bearing, egged out yokes, bad ujoints and bad front wheel bearings are my first concerns. I guess pinion backlash could be on the list of things to look at too but havent experienced it.
  9. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    Worn kingpin or lockjaws?
  10. Wajid8705
    66
    40
    Jun 9, 2018
    North Carolina
    I will check into that, I believe that's what it is.
  11. Trucker61016
    Trucker61016 Road Train Member
    1,077
    3,341
    Sep 18, 2017
    Linville, Va
    Because youre dancing without panties on ??
    booley, stillwurkin and FlaSwampRat Thank this.
