Why is my truck riding so rough?
Discussion in 'Questions From New Drivers' started by wjhuskey, Nov 1, 2014.
  1. wjhuskey
    wjhuskey Bobtail Member
    43
    15
    Nov 1, 2014
    My 1993 Peterbilt 379 EXHD has always rode rough. I think Peterbilt started making the cab/sleeper air ride in 1994. So sounds like I missed it by a year. But this is a long wheel base tractor and it seems like it should ride a little smoother. I haul grain off the farm during the harvest season with a hopper bottom trailer. Some people has said my fifth wheel may be set wrong. Its set so the front of the trailer is in the middle of the front axle tires (when looking at it from the side). Some have said I may need new spring eye bushings or torque bar bushings. I've looked at the spring eye bushings and can't really see anything but grease. The torque bar bushings don't look completely worn and the inspector didn't mention them when the truck was inspected a month ago. When I get on a certain road for my routine haul, it almost throws me out of the seat. Its a very rough road that has been needing to be repaved for about 10 years and they keep patching it in places which makes it even worse seems like. I've adjusted the leveling valve to where my trucking buddy said it needed to be. It was adjusted wrong when I first bought the truck so I thought that'd help and it did, "some". The truck has the short style air bags which probably isn't the best. Wonder if they could be swapped out for big ones? The truck feels every little bump in the road and on a rough road, I think I'm going to hit my head on the headliner. Does anyone know what the problem is? This is a Peterbilt 379...aren't they known for their smooth ride? Even the older ones???
    baha Thanks this.
  3. jbatmick
    jbatmick Road Train Member
    2,195
    2,458
    Dec 1, 2009
    hastings, Fl
    The leveling valve may need to be set different with those short air bags.Your buddy might not have them. Ask a Pete dealer.As a start, set your fifth wheel so the trailer king pin is slightly ahead of the middle of the two drive axles, then experiment.An inspector would probably not be trained to notice a worn bushing, a mechanic would. Usually the air bags setting control the ride bounce more than anything else.Tire pressure ?
  4. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    CK. the FT. springs to see how close they are to rubber stops that they hit when springs bottom out, if close to stops springs need to be re/ arched or replaced to make it ride much better, your long pete needs 5th wheel set about where it is over or just behind ft. drive axel to get weight on ft. end, a better drivers seat could help the ride also?
  5. HotH2o
    HotH2o Road Train Member
    4,098
    4,865
    Sep 23, 2012
    You need independent front suspension!
  6. wjhuskey
    43
    15
    Nov 1, 2014
    Baha, the driver's seat is a good seat. Its a Bostrom WideRide. I can tell the bounce is in the truck because the truck as a whole starts bouncing before the seat does. Its a straight up and down bounce which is usually worse loaded...and when I come to, for example, a road/bridge joint, it sounds like the back axles are going to break off; loaded OR unloaded. Jbatmick, tire pressure is about 100 lbs and I've ran it differently before. The inspector was actually my father in law who is a trained diesel mechanic, and he also is an inspector. He actually told me the sway bar needed replacing on my OTHER truck that he inspected, a 95' International 9400 Eagle. So obviously he looked at the bushings on the Pete. He also said the shocks needed replacing on one of my trailers he inspected so I can't figure out why nothing was mentioned about the Peterbilt. I'm surprised nothing was wrong with its suspension because something surely is. The road I notice it on is in horrible shape but I notice semi trucks behind me and I'm driving slower than they are. Something can't be right.
  7. Ridgeline
    22,112
    113,286
    "The torque bar bushings don't look completely worn and the inspector didn't mention them when the truck was inspected a month ago."
    Inspectors know crap about suspensions, bring it to a good shop and have the look at everything carefully.
  8. Old Man
    Old Man Road Train Member
    4,597
    13,469
    Apr 3, 2009
    Oklahoma City, OK
    Sounds like the shocks are worn out, you can't tell by looking unless you see oil leaks. Take one off and check it. without shocks your truck is just bouncing on the springs and air bags
    OPUS 7 Thanks this.
  9. bavarian
    bavarian Heavy Load Member
    727
    781
    Feb 13, 2014
    Winnipeg
    Try the shocks. I have the same experience at bridgejoints. Shocks are about due every 1 1/2 years. Some other drivers already talked about 50.000 mls on this forum.
    The reason why your father in law did mention a shock on some other equipment might be, that the shock was leaking and was wet on the outside. If your shocks are older, they might be dry already.
    What about your tirewear? Do they wear uneven?
  10. 315wheelbase
    315wheelbase Heavy Load Member
    783
    601
    Oct 26, 2014
    set your king pin on your tailer about 8 inches past the center between your drive axles,,to get a good ride you also should have between 11,000 and 12,000 on your steer axle,, your air ride on your drives loaded and empty should have 2inch clearance between the stop bock on top and the block on the axle..too much air rides hard too little and the air bag bottoms out,,
  11. wjhuskey
    43
    15
    Nov 1, 2014
    Bavarian, yes your probably right that they only look at shocks to see if they "look" good because my father in law said one was broke on the trailer and not even attached on one end. I haven't noticed any uneven tire wear. I just had a new rear end put in this truck and it was in a good, trusted shop. They said the U joints in the drive shaft had a lot of slack in them. They tightened that up for me too. I just wonder if traveling that rough road without good shocks done that. I just don't want to screw this new rear end up because of a rough ride. I've heard China tires can cause a ride like this and the truck has Sailun tires on it (made in china). I'm definitely going to look in to new shocks. Anyone driven an older Pete 379 like this? 93 and older? How did it ride with good shocks? I'm anxious to see for myself.....
