Why is it hard to put in gear?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by freightlinerman, Sep 1, 2012.
  1. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    I have an Eaton Fuller 9 speed. When stopped, some times it's hard to get into any gear. There's been times it's taken 20 seconds to put it in gear. I push the clutch to the floor, there is no grinding or anything I try 3rd, nothing, 4th, 2nd, 1st. I let of the clutch, wobble the shifter and try again. Same with reverse, I was trying to back or make a 3 pt turn it can be a challenge getting into gear.
    I"ve been in other trucks that have done this, just curious what I'm supposed to do to get it in correctly.
  3. Big Don
    Big Don "Old Fart"
    17,996
    35,643
    Sep 8, 2007
    Utah's DIXIE!
    Take it to the shop. Sounds like your clutch brake isn't working right.
    One thing you can do until you get it to the shop, is to put it into whichever gear you will be starting out in, as you are coming to a stop. Just do a standard down shift.
  4. bender
    bender Road Train Member
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    If you can feel the clutch brake in the clutch pedal before the pedal hits the floor and there is no grinding when attempting to put it in gear then try letting up slightly on the clutch pedal as you move the stick into position to go into gear. The transmission needs to be allowed to align gear teeth to engage in the gear especially in a good tight transmission with a good clutch brake.
    puncher Thanks this.
  5. freightlinerman
    1,287
    536
    Mar 4, 2011
    Florida
    Thanks. This doesn't happen all the time, but when it does its annoying.
  6. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    This probably happens when engine is warmed up. the clutch need adjustment, more likely at the linkage, not on the clutch itself. until you can get it looked at, with clutch to the floor, at a stop, if it will not go in gear, try to let up just a little on the clutch pedal & see if it will go in. when I fist got my truck, the clutch brake was not letting me put it in gear, like it should. even after new clutch put in, it went in easier, but not like it should, until I talked to my local shop, who DID NOT INSTALL THE CLUCTH, but any way for 30.00 he adjusted from the likage, just under the front bumper area. since then it works like a new one,no problem.
    Big Don Thanks this.
  7. puncher
    puncher Medium Load Member
    540
    358
    Feb 12, 2010
    Tn.
    What he said, I learned this many moons ago, and heavyhauler ss is also right about needing an adjustment to the linkage from time to time, but won't cause this but rather a very slight grind as you attempt to go in gear.
  8. freightlinerman
    1,287
    536
    Mar 4, 2011
    Florida
    I have a self adjusting clutch. Today for example when it wouldn't do it, I let up the clutch, shook the shifter, push the clutch 3/4 down let it grind a little and it went in.
