why double clutch istead of floating gears
Discussion in 'Questions From New Drivers' started by meat999, Jul 28, 2008.
  1. meat999
    meat999 Light Load Member
    67
    14
    Jul 20, 2008
    Det, MI
    I just wander why do you have to double clutch the gears in truck school
    when my instructor tells me you wont do this in the real world? It took me a minute to grasp it thank god I can do it now and got pretty dang good at it, but when im with my instructor he never touches that clutch only when starting and stopping. do I have to double or can i float like him?
  3. Ken Worth
    Ken Worth Medium Load Member
    639
    191
    Jun 29, 2008
    Great Plains
    The truck school guys say the manufacturers recomend double-clutching. If you get the chance, learn how to float.
    meat999 Thanks this.
  4. 25(2)+2
    18,756
    45,783
    Sep 18, 2006
    the road less travelled
    Float is the easiest way, and is easier on the clutch,but if you believe the manufacturers, no one should ever float the gears.
    I have gotten good enough to catch them on the way down, but it's harder with a N-14. The Detroit 14 is a very easy motor to float the gears with.
  5. MGASSEL
    MGASSEL Road Train Member
    1,301
    211
    Mar 27, 2007
    Co
    You must double clutch in school and on your road test to get your cdl. After you get on with an company you will have to listen to your trainer once you get your own truck you may do what you want. I float most of the time my trainer told me that we do not double clutch in his truck unless we have to.
  6. munrkr
    munrkr Medium Load Member
    375
    27
    Dec 14, 2006
    The cluth is there to take punishment as it were. Clutch replacement is minor compared to more serious damage cause by forcing shifts without it's benefit. Now having said that, the main reason for floating is because often times rpm's fall to quickly, especially for rookies when they're trying to double clutch under load. Shifting takes practice, even old hands miss a gear sometimes. So for those starting out, for a equipment protection standpoint, d/c'n might be the way to go. But as soon as ya get the hang of it, skip the crutch... I mean clutch, and join the ranks of the pro's.
    Of course I could be wrong ...
    Tb0n3, scottccal and meat999 Thank this.
  7. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    I agree except I don't think floating means you're a professional!! The concept is to know what gear to be in at any given time. If you can hit those gears without banging then go for it. And when I say banging that doesn't mean grinding or rubbing it means a bang. It won't happen very often but when it does that when the damage occurs. And it's usually when you're under a heavy load. So I believe every new driver should learn how to double clutch then when he or she KNOWS the truck they can shift any way they choose to take care of that equipment.
  8. Globetrotter
    Globetrotter Light Load Member
    156
    43
    Nov 7, 2007
    everywhere
    Our school only taught us how to float gears---
    CDL test I floated the whole time and passed.
    Now the company truck Im in has an auto shift with a clutch pedal thats used only for starting or stopping.
    I say just learn how to float em... don't shove it in gear ever. When the rpm and road speed is correct the lever will slide in with a minimal amount of pressure.
    I even float gears some times on my pickup at home and my Vw bus.
  9. Truckerjo
    Truckerjo Road Train Member
    2,314
    341
    Sep 5, 2006
    Indiana
    Well why not float? as new driver you going to grind gears... If you miss a shift while double clutching your going to hear a grind.. With a missed gear while floating you can get a load clunk that seriously can tear crap up.. Thats why you should start with double clutching till you get the shift timings down VERY well then practice floating....
    Tb0n3 and meat999 Thank this.
  10. meat999
    67
    14
    Jul 20, 2008
    Det, MI
    my school would frown on floating-- you must double to pass ypur cdl -- i did float by mistake when i was trying to downshift and my instructor told me that was an automatic fail. so you went to a #### soft truck school. do you even knoe hoe to double clutch??
  11. MGASSEL
    1,301
    211
    Mar 27, 2007
    Co
    one of the rules in colorado for the third party testers and am sure everywere else is you must double clutch .
