Just wonderng why a dump or logging truck doesnt need an authority? From the basic rules of needing an authority that I know of, for example crossing state lines, not leased on to a company, hauling for hire (other peoples goods). How does this not include dump or logging trucks?
I have a good friend who owns his own logging truck. He usually hauls for the same companny but has no lease with them, and he sometimes crosses state lines from NC to VA.
Why do dump/logging trucks not need an authority?
Discussion in 'Ask An Owner Operator' started by NCstroker, Oct 4, 2007.
My first employer didn't have authority on both of his tractors, he would purchase a temporary permit to operate in other states on the tractor without it.
You only need authority to haul manufactured products. You can haul agricultural products without an authority.. You can technically run a trucking co only hauling ag products but it's very hard. I used to have a good friend who hauled only produce, hay, and bulk potatoes. He never had authority but it was a hard way to make a living and he ran empty alot.
This was 12 years ago, I don't know if things have changed but I believe they have not. -
I don't know what it's called anywhere else. Here we run 82K on 4 axles 88K on 5 axles, 92,400K on 6 although they are not allowed on the interstate. The DOT sets up portable scales regularly on the mill road and the loggers have NO choice but to cross them or park and wait them out. Most wait them out as the ticket is over $700 bucks in this county, every county is different on fines. Don't get a log book violation they went up to $500 bucks PER violation. -
Things such as fresh produce, agriculture goods, such as hay, water, gravel, dirt, logs, or most any non-manufactured good is known as an Exempt Commodity, needing no authority.
After some of these things are processed at a plant or mill, then authority is needed to haul. -
All they are required to have is a USDOT #
They are considered interstate motor carrier (for those that do cross state lines as is common here in the carolinas), For-Hire exempt property Carrier.
All that requires it is to fill out form MCS-150 USDOT and from MCS-150A saftey certification.
