Who makes the cheapest Daycab?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Blackducati750, Oct 7, 2009.
  1. Blackducati750
    Blackducati750 Light Load Member
    193
    10
    Mar 11, 2009
    Bushkill,PA
    Someday, (fingers crossed) I'll sign on as an O/O with the company I work for now and make INSANE money in the process.
    But, I'll have to buy a truck. Many people say I should buy a good used truck as my first. Considering I'm looking foward to a warranty, I decided that I'll just buy something new...
    So, Let's say I walked into a Peterbilt / Mack / Volvo / International / Sterling / Freightliner / Western Star / Etc. dealership and pretty much said the same thing...
    "I want the smallest daycab you make that can still be reg. to 80,000lbs (twin screw), with the biggest engine available for that model, a 10-speed Eaton trans, and a "no-frills" cab (base model interior).
    Who will make the cheapest daycab?
    A friend of mine said that Freightliner makes the cheapest truck. (Columbia??)
    I'd like everyone's opinion.
    Thanks!!!!!!!
  3. The Challenger
    The Challenger Kinghunter
    7,127
    3,367
    Dec 22, 2007
    East Central FL
    Your friend is right on Freightliner being built cheap followed by Volvo/Mack, International, and a tie between KW and Peterbilt Many truck manufacturers have a lightweight spec option. Are you running OTR, regional, or local?
    KH
  4. Luis
    Luis Medium Load Member
    662
    323
    Aug 10, 2008
    How can you run otr in a daycab sometimes it makes me wonder how you come up with this stuff. I know some that do it but cost's alot in hotels. So your calling mack cheap and international? Some of the trucks that are still built strong? Do some research before you start trying to be an expert.
  5. kwforage
    kwforage Road Train Member
    1,047
    472
    Jun 3, 2007
    Wisconsin
    cross that one off the list
  6. Got reefer?
    Got reefer? El Coyote
    187
    126
    Jan 9, 2009
    Midland, TX
    Freightliner probably be your best bet. Id stay away fro mack/volvo they arent reliable in my books and certainly not very light either. I cant really comment on international except i doubt they would be very light. Stay away from sterling. Western star is made by freightliner now so you might check into them. You might you could pull of being light with a little style in a WS. Peterbilt and kenworths probably not gonna be very light.
    Also you might want to look into older trucks that arent going to have all this new emissions crap on them. Have you seen one of these new mufflers they are hug no telling what they weigh.
  7. Blackducati750
    193
    10
    Mar 11, 2009
    Bushkill,PA
    Local, maybe 450-550 miles per day tops...
    Is there a difference between built cheap and costs cheap?
    Does that mean the more expensive truck will have a better build quality even though it has the same engine/trans/rears as the cheaper truck?
  8. Got reefer?
    187
    126
    Jan 9, 2009
    Midland, TX
    You can take the same drivetrain out of a KW and put it in a Volvo and over double your down time. At least that was my experience.
    You get what you pay for.
  9. Blackducati750
    193
    10
    Mar 11, 2009
    Bushkill,PA
    Doesn't make much sense to me, but I'll take your word for it....
  10. Big Duker
    Big Duker "Don Cheto"
    2,921
    2,867
    Sep 18, 2007
    Weatherford, TX
    You can get many used trucks with good warranty. FL is just about always going to be the cheapest to get into. And they have thousands of them on the used market always. They piss me off with stuff falling off, but they do get the job done economically. You can always look into new if your gig works out as well as planned. With the economy in the toilet I would keep my over head as low as possible. And have some cash put back. You WILL need it. Good luck.
  11. pullingtrucker
    pullingtrucker Road Train Member
    1,185
    598
    Dec 21, 2008
    Fostoria, Ohio
    First off, why would you want the biggest engine you can get and a 10 speed? This makes no sense at all. There are more factors than just finding the "cheapest daycab" and the options you listed. Trust me, once you see what it is like to be a o/o your tune will change on all aspects of trucking. My opinion would be to find a truck with a 48' sleeper and a decent size engine that is geared right with a 13 speed. Also since you spend the majority of your time in the cab, you will want the creature comforts...trust me, I have been down the road you want to go. Now if you are a HP/TQ junkie like me you will want a big cube motor infront of a 18 speed with the right gears and full locking rears and 40+ axles. Personally I wouldn't look into a new truck just because of all the emissions, I would look for a good used daycab and make my money with it until the EPA says no more.
    The Challenger and rwings Thank this.
