white smoke missing after replacing number 4 injector, cat c15 6nz
Discussion in 'Trucks [ Eighteen Wheelers ]' started by cumminsISB, Sep 20, 2014.
  1. cumminsISB
    cumminsISB Light Load Member
    176
    10
    Feb 5, 2011
    D'Lo, Ms
    started truck up Thursday morning after sitting approximately 10 hours. Was smoking white smoke smelled like raw diesel, was also running rough. Cleared up after getting to operating temp. Delivered my load went home empty to find/fix problem. Took off exhaust manifold and number 4 was blowing smoke...smelled like raw diesel. replaced injector with a cat reman, run complete overhead, put everything back together. was smoking really bad from diesel fuel. And now it is still doing the same thing. Need some advice and suggestions. From reading on here sounds like a crack or head gasket on number 4. why would it start this all of a sudden?
  3. BeenJammin
    BeenJammin Light Load Member
    256
    118
    Dec 17, 2013
    Fire ring lost it's crush awhile back and it's burned through. Yank you a few head bolts around and between #4 and 5, more than likely they'll be carboned up pretty bad.
    cumminsISB Thanks this.
  4. Truck engine machinist
    Truck engine machinist Light Load Member
    195
    185
    Dec 2, 2011
    USA
    Sounds like a possible injector seat (not injector cup) problem.
  5. cumminsISB
    176
    10
    Feb 5, 2011
    D'Lo, Ms
    Exactly what happenen. Hope that liner didn't drop. Did not look like it, but I am going to have an expert look at the block.
  6. Felix90
    Felix90 Bobtail Member
    Could you tell what the problem was? I'm having the same problem.
  7. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,056
    Nov 18, 2014
    Land of local
    It's been 7 years since he was last seen, start a new thread if you want
