white smoke from oil dipstick
Discussion in 'Trucks [ Eighteen Wheelers ]' started by venodaren, Dec 20, 2012.
  1. venodaren
    venodaren Bobtail Member
    47
    Malaysia
    Model : Scania 124 L 420 2001
    hi guys..there is white smoke coming out from the oil dipstick of my truck..why this happens??..
    my mechanics said Scania does not have any engine breather whereas for Volvo there is..is it true????
  3. Gear head
    Gear head Medium Load Member
    532
    91
    Apr 1, 2012
    Belair,md
    If it is dripping oil from blowby then you have rig problems, if it is dripping coolant from blowby hose then you have coolant in oil. Stick your finger in blowby hose and see if you have discolored gelly like substance in hose, if you have jelley stuff you have coolant in oil and the smoke you see is coolant boiling out of the oil. Alittle bit of oil is no cause for alarm if it drips once a min. or so then you have a problem and the smoke you see is excessive blowby of the pistons.
  4. serozhah
    serozhah Light Load Member
    283
    45
    Sep 8, 2013
    i've noticed the same thing in my 2000 freightliner. Like lots of smoke coming out of the dip stick. But almost nothing coming out of the blow by hose. I assumed blowby hose is the one under the truck that I can see blowing exhaust somewhere in the area of the front right steering tire. So is it normal or is there a problem that I still get lots of exhaust looking air coming out of oil dip stick? Thanks
    30-aught-6 Thanks this.
  5. rebeloutlaw66
    rebeloutlaw66 Light Load Member
    199
    41
    Sep 2, 2009
    You may want to check and see if your blowby hose is stopped up
  6. serozhah
    283
    45
    Sep 8, 2013
    if it was stopped up, no air would be coming out of it, right? Since I see exhaust looking air coming out of it, it means the hose is not plugged up, right? Thanks
  7. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    Could just be condensation. How much are we talking here?
  8. serozhah
    283
    45
    Sep 8, 2013
    out of the dipstick, its hard to tell cause its almost clear air that is coming out. But that slightly smoky air is blowing out of the dipstick day and night, rain or dry, so always, i think. maybe like half to a quarter of what is comining out of blowby hose is coming out of the dip stick. I know the truck has major blow-by cause it has lots of miles on it. I also lose about a gallon of oil a week. The good thing is that mpg of the truck is really good
  9. Heavyd
    7,749
    6,184
    Feb 4, 2009
    It is probably blowby with some condensation. There is always some moisture in the air that will turn into some steam and get into the crankcase due to blowby. If the smoke quickly dissipates and totally disappears a few inches away then I would say it is just moisture with some blowby gases. This is normal with an older engine that has a lot of miles on it. To be expected.
    serozhah Thanks this.
  10. serozhah
    283
    45
    Sep 8, 2013
    omg, i replaced my oil filler cap that had no sealing capacity (broken nut). Its been a week with the new oil filler cap that actually seals in the filler tube. I thought it would make no difference, but i lost like no oil over the last week of driving (like 3000+mi of driving). I've read online that bad oil cap can leak oil, maybe i was losing that gallon of oil through the BS oil cap and not blow by!!
  11. old time
    old time Medium Load Member
    304
    334
    Mar 1, 2012
    When you have a lot of blowby it builds pressure in the crankcase. Pressure has to go somewhere and out the dipstick is path of least resistance
