Which engine rebuild kit is better? Cummins vs Kenworth vs Engine parts Canada
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Gurjap, Feb 14, 2021.
  1. Gurjap
    Gurjap Light Load Member
    57
    11
    Mar 18, 2020
    Hello friends,
    I have a 2010 Kenworth T800 Cummins isx(may 2009) which is due for a rebuild. I have three companies from where I am planning to get a kit from. One is “Engine Parts Canada” which is the cheapest option sitting at 4900 CAD. Second, is from Kenworth where the same kit costs 6300CAD. And lastly, from Cummins itself where the kit costs 8000CAD. Based on your professional opinion and experience. Which company should I get it from because I am unaware of the quality in each kit.
    Please get back to me at your earliest convenience.
    Thank you.
  3. AModelCat
    154,240
    Myself, I wouldn't put aftermarket parts in.
  4. Nostalgic
    Nostalgic Road Train Member
    1,782
    19,568
    Mar 6, 2017
    PA
    ISX = OE only. Unless you love doing the job yearly.
  5. little cat 500
    2,044
    1,090
    Jan 17, 2010
    Abbottstown PA
    id put the cheaper kit in ISX dont run long anyways
    pavrom Thanks this.
  6. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    Why is Kenworth trying to sell you an aftermarket kit?
    They should have the Cummins kit available or be able to order it, and they are usually cheaper than buying direct from Cummins.
  7. God prefers Diesels
    4,198
    22,258
    Jun 26, 2020
    South Texas
    Mine's 14 years old, and about to hit 900k. How long is "long"?
    BoxCarKidd and Shawn2130 Thank this.
  8. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,431
    Aug 26, 2014
    Some of those had problems with carbon packing. That is on the piston above the top ring and it polishes the liner. Then they start passing enough oil to stop up the DPF. Cummins made changes to their piston design to correct that problem.
    I use a lot of aftermarket parts. Clevite, PAI and Max Force with great results. However if the OEM has struggled with piston designs for their own engine I would not buy aftermarket parts for that. Get the Cummings kit from and dealer not Cummins. The price structure alloys them to mark it up and sell it for less than OEM to you as others stated. Shop it around.
  9. Farmtractor9900
    Farmtractor9900 Light Load Member
    162
    433
    Nov 6, 2020
    Kenworth and Cummins are OEM kits. Are Engine Parts Canada kits OEM and what kind of *warranty do they offer?
    Cummins will always be more expensive than its distributors.
    I would go with Kenworth.
