I am purchasing a 6x6 military truck that comes factory with a cummins 250hp engine (very underpowered). To upgrade this engine to anything over 350hp will cost a ton of money, and would not be a good value. I have decided on swapping a Caterpillar 3406 engine in it's place with the help of my father in law who is a mechanic. Which version of the 3406 should I start with? The 3406b has a lower initial investment, but the 3406e seems easier to upgrade via ECU upgrades. I plan on buying an OTR tractor complete so I would have all of the electronics intact. I would love to have around 600hp to start with, but I love power so plan on the best upgrade path to 1200hp down the road.
Which Cat 3406 should I start with for maximum HP
Discussion in 'Trucks [ Eighteen Wheelers ]' started by staffcurtis, Dec 10, 2012.
Page 1 of 6
....and I forgot to mention for this project, fuel mileage is not a concern.
If your wanting over 800hp your best bet would be to get a 2WS, 1MM, 6NZ, 7CZ or MBN. MBN only if you want to do a rebuild before you put it in as the pistons, cam and injectors wouldn't be as good as the previous prefixes. They're all 70pin ecms.
You could probably go with a 1LW as well but their known for breaking the cranks. Although if they have high mileage good chance the crank won't break. Normally if they're gonna break it will be before a million miles on the crank.
If you want over 800hp stay away from a 5EK as they are prone to cracking the block over 800hp. Can't remember if the 6TS had solved that issue or not... I know the 1LW definitely has a stronger block than 5EKstaffcurtis Thanks this. -
I assume underpsi that you are preferring the 3406e over the mechanical 3406b model. Will it take more than an ecu program to see the 800hp mark? What more will it take to see 1200hp?
What could be expected if the 250 was turbo charged? I'm guessing it would be good for another 150 hp.
How many rpms is the cummings running at 55? -
5EK, 6TS, 1LW and 5DS are all 40pin 3406Es easy to make 800hp with. 2WS, 1MM, 6NZ, 7CZ and MBN are all 70pin ecms a set of injectors, turbo and ecm program and easily over 800hp. -
If you start with a good base engine, you will need a cam, turbo, injectors, and a ecm upgrade. Then you would have to upgrade most of your driveline in that truck to handle the power and torque.
starmac Thanks this. -
Underpsi- Will the 40 pin ECM engines you listed require turbo and injector upgrades for 800hp?
You're not gonna get 800hp out of anything for very long without getting a suitable turbo. 800hp could to obtained with a 5EK or 6TS with a higher factory rating (475 or 550) as most of those engines all have bigger injectors. With the right file in the ecm you could get away with 800hp without the cost of buying injectors.
Page 1 of 6
