Which air pump for unloading tankers?
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by FordFan, Aug 5, 2013.
  1. FordFan
    FordFan Light Load Member
    83
    31
    Jul 18, 2013
    Will need to buy a pump to unload chemical tanker. Parts rep has been trying to sell me on a Quincy piston pump. I will be hauling caustic soda.
    what pumps do you guys run/ recommend?
  3. lv gn
    lv gn Heavy Load Member
    985
    469
    Jun 23, 2008
    las vegas nv.
    I'm pretty sure that's the brand I have on my company truck. Ill look at it when I get to the yard.
  4. chalupa
    chalupa Road Train Member
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    U sure you even need one? Caustic is heavy and rolls in a small trailer. Many I know use tractor air or plant air to off load.
    You keep your gear on at all times and that shield down when close to any connection. Get you a bottle of boric acid too for neutralization. Find and test the shower at every location BEFORE you hook up. Look at every gasket every time, change as needed.
    The solution is dilution, water is your friend........
    JMO / JME
    Big Duker and Chinatown Thank this.
  5. FordFan
    83
    31
    Jul 18, 2013
    Unfortunately I will need one. Some of the locations i will be delivering to remote tanks. The stuff is quite heavy, almost 13lb/gall.
    if you don't mind, see if you can find the model # on that pump.
    thanks for the help guys.
  6. wis bang
    wis bang Road Train Member
    3,348
    3,916
    Jan 12, 2011
    Levittown, PA
    Quincey is a old established manufacturer of air compressors w/ a good reputation in the chemical industry. Girard Equipment used to sell a little vee unit , manufacturer was 'Emglo' they worked well but quincey's often got moved to the next truck!
    Biggest thing is to have the correct ratio PTO which is different than one for a liquid pump like a Roper, Viking or Blackmere.
    chalupa Thanks this.
  7. lv gn
    985
    469
    Jun 23, 2008
    las vegas nv.
    My truck has a Quincy. Model QTS-5
    all our trucks have them and in 5 years I never heard of one going bad at our plant
  8. FordFan
    83
    31
    Jul 18, 2013
    Thanks! That's the model I was recommended by a sales rep.
    lv gn Thanks this.
  9. wstar2003
    wstar2003 Light Load Member
    157
    195
    Jul 14, 2013
    I had an old Quincy that was rebuilt by a friend of mine when I bought it. I hauled Phosphoric acid and used it 2-3 times a week for four years. It finally started pumping a little oil so I looked about having it rebuilt and it turned out that it was so old some of the parts were high for it. I would estimate that old thing ran roughly ten years on one rebuild. They are indestructible as long as you change the oil in them. A new one probably costs about $600. Will unload caustic forever with no problems. But you are right you will need it when there is no plant air unless you have a big compressor on your truck.
  10. thirdreef
    thirdreef Medium Load Member
    602
    185
    Jul 8, 2013
    Reno,Nv
    Gardner Denver makes a small one for tankers. It is a rotary set up.. Go to their web site, and they will show you the bigger ones for dry bulk .. But the have one small one. Bulk equipment handles them .
  11. wis bang
    3,348
    3,916
    Jan 12, 2011
    Levittown, PA
    GD made a good bulk blower. the early ones were real loud but they re-did them, lighter, less noisy & powerful. Never saw one for liquid.
