Does the FMCSA have specific locations to mount a fire extinguisher in a cargo van? My future employer requires me to carry one in the can, but I'm not sure where to mount it. I was thinking about mounting it to the passenger side door support beam. Any help will be appreciated.
Thanks,
Phat Kat Jw
Where to mount a fire extinguisher?
Discussion in 'Questions From New Drivers' started by Phat Kat JW, Aug 26, 2011.
I would say, and I am not an expert, where it is quickly and easily available. I am in a Ryder rental and they mount it between the drivers seat and the door, on the floor. The only problem I have with that is my seat belt keeps getting caught in it and some day I will set it off putting on my belt. I do keep unhooking the mounting clip.
Be sure its mounted is the main thing
Most trucks they are mounted on the floor either behind or next to the drivers seat.
yeah thats were ive seen them mounted but i keep unhooking the #### thing with the flipen seat belt. gets kinda annoying. as for dot saying dont think they overly care. u could probably get away with putting it in your side box as well
Wherever you put it, get the decal that reads Fire Extinguisher Inside. Helps with DOT.
mine was beside my seat, until I smacked it with my foot breaking the pin and setting it off. Now it's in my side compartment mounted to the wall.
Passenger side between door and seat keeps it out of the way, easily secured, and still available for inspections and fires.
http://www.fmcsa.dot.gov/rules-regulations/administration/fmcsr/fmcsrruletext.aspx?reg=393.95
393.95
Emergency equipment on all power units.
Each truck, truck tractor, and bus (except those towed in driveaway-towaway operations) must be equipped as follows:
(a) Fire extinguishers'
(1) Minimum ratings. (i) A power unit that is used to transport hazardous materials in a quantity that requires placarding (See §177.823 of this title) must be equipped with a fire extinguisher having an Underwriters' Laboratories rating of 10 B:C or more. (ii) A power unit that is not used to transport hazardous materials must be equipped with either:
(A) A fire extinguisher having an Underwriters' Laboratories rating of 5 B:C or more; or
(B) Two fire extinguishers, each of which has an Underwriters' Laboratories rating of 4 B:C or more.
(2) Labeling and marking. Each fire extinguisher required by this section must be labeled or marked by the manufacturer with its Underwriters' Laboratories rating.
(3) Visual Indicators. The fire extinguisher must be designed, constructed, and maintained to permit visual determination of whether it is fully charged.
(4) Condition, location, and mounting. The fire extinguisher(s) must be filled and located so that it is readily accessible for use. The extinguisher(s) must be securely mounted to prevent sliding, rolling, or vertical movement relative to the motor vehicle.
(5) Extinguishing agents. The fire extinguisher must use an extinguishing agent that does not need protection from freezing. Extinguishing agents must comply with the toxicity provisions of the Environmental Protection Agency's Significant New Alternatives Policy (SNAP) regulations under 40 CFR Part 82, Subpart G.
(6) Exception. This paragraph (a) does not apply to the driven unit in a driveaway-towaway operation. (b) Spare fuses. Power units for which fuses are needed to operate any required parts and accessories must have at least one spare fuse for each type/size of fuse needed for those parts and accessories.
