Havng a hardtime looking up parts for my truck. (96 pete 378)
So far ive only found my local truck shop to get parts but Id look to look them up online.
Anyone have any recommendations? maybe a site that I can use to look up parts with my vin number?
Thanks
Where to lookup/find oem parts?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by irishluck09, Feb 9, 2020.
Page 1 of 3
If it helps im trying to find a fan clutch, push/pull valve for trailer brake air supply, possibly a new block heater, full locking differential toggle switch, and dipstick.
Pete store dot com for oem, parts truck pro or fleet pride or any local truck parts store like Napa o Riley depending on whereabouts you live northern Indiana has power brakes and springs store,
Peterbilt was more like an assembler than a manufacturer. Most things on the truck will be made by another company. If you can identify who made the original part it makes searching easier. Some things like electrical parts will be the same across multiple trucks and manufacturers but with different connectors. You can buy the generic part and put the connectors on to match what you have. The wiper switch and turn signal stalk are like that. The double rectangle headlights were used by several manufacturers. I bought new springs for mine from the local Blue Bird bus dealer and the adjusting screws are Dorman from Autozone or Rock Auto
Fan clutch, block heater, dipstick - specific to your engine (somewhat), probably made by a third company
Try Horton for the fan clutch: https://catalog.hortonww.com/index.html
Trailer air supply and locking diff toggle
Velvac - https://www.velvac.com/sites/default/files/resource-files/04-air_0.pdf
Tramec Sloan - https://tramecsloan.com/wp-content/uploads/2018/09/TS-Full-Line-Catalog.pdf
I have the build sheet for my truck but it doesn't do as much good as it used to. Peterbilt changed a bunch of part numbers a while ago. Even if I go into the dealership with a part number they have a hard time finding what I need. Not much interest from them in keeping a 30 year old truck on the road -
Interesting. It be nice if they had like a lookup you could use. Like for motorcycles lol or like my local dealer can use the last 6 of my vin to look up parts.
I think I was able to find the fan clutch from horton. Remaned for $742. I think ill just rebuild it myself. My local shop here has a kit for $404.
So what i was shocked about was the local shop can get me a push/pull trailer brake valve but for like $180. I was shocked. I didnt think they were that high and mine just has a small leak. So ive been looking online but there are so many different options, so im not sure which one I need.
These are the ones I found but im not sure which one would replace mine. I guess I just need to take it off and look?
Push-Pull, On-Off Valves: AnythingTruck.com, Truck & Trailer Parts and Accessories Warehouse -
What year is your truck and what engine does it have? -
Pretty sure this was the company that made my current fan clutch:
https://www.fanclutch.com/PicsDocs/Kit-Masters-Catalog-2015.pdf -
My rig is a 1996 pete 378 with a 3406e 5EK.
Yea the previous owners of the truck I guess did a quick fix on the fan clutch and welded it together. So its always on. So im trying to find the cheapest, yet of coarse best way to get it fixed. I can grind off the welds they did as their are just a few tacks that was done.
Is a rebuild hard to do? Custom Truck, here in KCMO, has a rebuild kit for $404. Ill have to check fleetpride and see what they have to offer. Theres one local here.
So my trailer brake push/pull valve, I have a small air leak behind my dash board and what it is, is one of the air lines going into the valve it seems like the push connector is just wearing out. But from what I can tell, the whole valve has to be replaced.
I attached a pic of an example where the leak is coming from for reference.Attached Files:
I'm not familiar with the cat fan clutch. On my cummins it's pretty easy to take the snap ring off the back side and pull everything apart. I've got a toolbox full of various pullers and can usually find something that works
The least expensive way would be to grind the welds, take it apart, and track down the parts. The kit may or may not cost a lot more than the individual parts. Bearings will have the size stamped on the side of the race. They should be easy to track down. Some bearings may seem special but aren't. The bearing in my water pump pulley is a bit odd since it only has a seal on the back side. The front is open and you're supposed to pack the inside of the pulley with grease before pushing the bearing in. in stead of ordering the bearing with only one seal I ordered the cheaper standard pulley, then pried the seal off one side and installed it. Same end result, cheaper part
All that takes time. You just have to weigh out if it's worth it to take that time or not. My truck sits on job sites for a month of two so I don't have to drive it to make a living
For the air valve: If you have enough air line, sometimes all you need to do it pull it out, cut some of the end off, and reinstall it. Just gives a clean section of hose for the connector to seal to. Besides that I'm not sure what parts can be replaced on that valve individually. My truck is an '89 and has three individual valves for trailer emergency, system park, and charge trailer -
IMO, just buy a new hub. The amount of dicking around trying to save $200 isn't worth it IMO.
I glide 47, SAR and Mattmanstroked Thank this.
Page 1 of 3
