Where to get a ECM wiring harness for a N14 Cummins
Discussion in 'Experienced Truckers' Advice' started by Tabby101, May 21, 2018.
  1. Tabby101
    Tabby101 Bobtail Member
    6
    I need to find a place that has an ECM harness for a N14 cummins. I havesearched around and can't seem to find one under $300.:mad:Any ideas ofjunkyards or used parts stores?
  3. mrbamcclain
    mrbamcclain Light Load Member
    258
    116
    May 25, 2011
    Hammond, La
    Tabby101 Thanks this.
  4. Ridgeline
    22,599
    119,963
    Between I think the other two threads from the op, everyone tells the op buy new.
    Lepton1 and Tabby101 Thank this.
  5. Tabby101
    6
    UPDATE
    So it seems I do not need the entire harness. All I need is the small plug from the engine...the one with the least amount of wires. Mine was cut about 8 inches back. I ordered one from a junkyard of North for 75 bucks. The problem I have now is the wires are not numbered or colored the same as mine. The plug actually fits I just have no way of knowing which wire's to connect.
  6. spindrift
    spindrift Road Train Member
    3,233
    12,905
    Dec 2, 2014
    Texas
    The wires should be numbered.
  7. Ridgeline
    22,599
    119,963
    If I remember right, you have to have a special tool to remove the contacts on the plug.
  8. mrbamcclain
    258
    116
    May 25, 2011
    Hammond, La
    Even more reason you should have just bought a new harness. Chasing unknown wires is just more time wasted.
  9. spindrift
    3,233
    12,905
    Dec 2, 2014
    Texas
    True...special tool needed to remove the pins from the harness connector.
  10. Tabby101
    6
    They are numbered but none of them match.
  11. Tabby101
    6
    Yes you do need a special tool and it was an ex-employee with a vindictive streak.
