Does anyone know where the injector for the DPF system located on a Paccer MX-13? Has anyone replaced one them self? How complicated is it?
Where is the DPF system injector?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by SemiMan, Dec 12, 2016.
You mean doser injector? If so, should be behind turbo
Usually their are two. One is just behind the turbo. That one is used for active regeneration while driving. Then other one is by the DPF and is used for parked regeneration. That's how Detroits and I believe Cummins are set up
The seventh injector refers to the injector next to the DPF filter. The ones used for parked regeneration. Unless paccar is different
It's behind the turbo, ahead of the DPF.
Not rocket science.
You will need something to catch a lot of your coolant, because it is cooled.
May or may not need to update your ECM as well.
Look at RAWZE on UTUBE. He has step by step for Cummins doser.
Paccar same principle. -
Ya i already saw that thanks. The CEL is DPF injector #1 no response so i would imagin its the one right after the turbo.
How many hours on the engine and how long since it was last it cleaned? They plug up with soot, we clean them every 4500 hours with the DPF cleaning. Same with the DEF doser in the pipe between the DPF and SCR system. Not hard to do, but you do have to drain the coolant. Use come carb cleaner and a brass wire brush. A clogged doser is the #1 cause for a not responding fault.
So i took the doser after the turbo and cleaned it very well, but the cel is still on. Is there a way i can reset the cel without going to the dealer?
Truck only has 270k, 2014 T660 with a Paccar MX13.
