When to plug in an engine block heater
Discussion in 'Questions From New Drivers' started by SteveR1954, Dec 11, 2021.
  1. SteveR1954
    SteveR1954 Bobtail Member
    7
    9
    Dec 11, 2021
    I drive a 2016 IC CE school bus, and this is my first winter as a driver. The manual says "At temperatures of 4 degrees F or below, it is recommended that you use a crankcase-mounted coolant heater to improve cold engine starting." I am assuming that the unbranded diesel fuel we obtain from a BP convenience store pump is #2 diesel. (Am I wrong?) The gel point for #2 diesel seems to be well above 4 degrees. So I'm confused. When should I plug in the block heater on my bus?
    austinmike Thanks this.
  3. Lazer
    Lazer Road Train Member
    1,821
    2,904
    Jan 22, 2017
    The ‘gel point’ for straight #2 diesel, should be well below zero Fahrenheit. The ‘cloud point’ should be a few degrees above zero.
  4. ZVar
    ZVar Road Train Member
    10,911
    23,830
    Sep 10, 2010
    Flint, MI
    Why not ask your coworkers what they did last year? Or company policy for that matter?
    roshea, austinmike, Bean Jr. and 2 others Thank this.
  5. Kyle G.
    Kyle G. Road Train Member
    3,901
    20,570
    Jan 23, 2016
    Eastern Iowa
    The block heater doesn’t do anything to keep your fuel from gelling. All it does is warm the engine oil enough to make it easier to start.
    I usually plug my truck in any time it gets below 20 degrees F. But mostly that’s just because I am a wuss in my old age and I like it to warm up faster lol.
  6. TripleSix
    132,167
    It’s not the gelling I was worried about, but the engine oil. Extremely cold engine oil doesn’t want to flow and the engine clanks and rattles as if it’s going to blow apart.
  7. clausland
    clausland Road Train Member
    1,933
    11,067
    Dec 5, 2014
    North Woods
    Not to mention tearing up the starter. I always plugged in 20F or colder..
  8. AModelCat
    161,251
    Diesel engine I'd plug in at 32°F or colder. A gas engine I'll leave it until it gets around 10°F or colder.
    As was mentioned already, you're not heating fuel, you're heating the engine block with a heater element submerged in a water jacket on the engine. You'll get minimal heat into the oil so if you own the bus, I'd consult the manual and use the oil grade recommended for the ambient temperature you see most often. If its not your bus, just plug it in and don't worry about it.
    Last Call, bzinger, austinmike and 8 others Thank this.
  9. Flint1
    Flint1 Road Train Member
    1,154
    9,880
    Sep 4, 2019
    Alberta
    2016 more then likely has a cummins ISB. Good cold weather starters. I plug ours in about -2C, 26f.
    They start easier, but its not necessary.
    They will start unassisted at -20c, -5f ish but sounds like it's falling apart.
    Having the correct oil for cold starts is important.
    Almost the same engine as in dodge trucks.
  10. SteveR1954
    7
    9
    Dec 11, 2021
    Oh yeah . . . a few different sources told me that #2 diesel gels at around 17.5 degrees, and I then proceeded to somehow mix apples and oranges in my post - coolant and diesel. I already know what other bus drivers say and do in regard to plugging in the bus heaters. Some play it safe and plug in when temperatures dip down toward freezing, some wait for single digits. I came to this forum to garner more technical information. The bus is not mine. Thanks very much.
    Kyle G. and Pamela1990 Thank this.
  11. SteveR1954
    7
    9
    Dec 11, 2021
    You're right. It is a Cummins ISB, and you have described my situation. Thanks!
    Pamela1990 Thanks this.
