When to Change Belt Tensioner and Pulleys?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by PE_T, Nov 28, 2018.
  1. PE_T
    PE_T Road Train Member
    Is there a mileage when to change these? How do I know if mine is bad or about to go out? I have a 2014 Freightliner Cascadia (DD15).
  3. iraqralph43
    iraqralph43 Road Train Member
    1,688
    2,733
    Jan 9, 2012
    Changed both last week at 350,000mi...after belt broke because of bad pulleys and belt tensioner
    Rideandrepair and PE_T Thank this.
  4. PE_T
    I must be lucky. I don’t think the tensioner and pulleys have ever been changed on my 680k truck! I guess it’s time to change them before I end up on the side of the road.
    Rideandrepair Thanks this.
  5. Working2party
    Working2party Medium Load Member
    608
    729
    Feb 10, 2018
    Kansas
    My fleet runs in a ruff, off road, and short haul conditions, we change the belts once a year (@100,000 mi), we’ve started using the Gates HD belt.
    The belts made today are built so they don’t break, Dayco makes a go-no-go gauge for belts that works well to tell if it’s time. But it sucks waiting for the belts to tell you it’s time to replace them. Because it’s always either the hottest or coldest day of the year, and it’s always a spot that is the farthest away from the shop as possible!!!
    We have also found that in our rough conditions that the OEM tensioner has been the cause for many of the belt failures. The Gates tensioner has served us better so far.
    But if you’ve got 680k o your belts, what ever you’re doing is wiring and you shouldn’t mess with it!!!
  6. PE_T
    Hahaha. I actually have changed my belts (at 630k). My truck had 350k when I bought it. I don’t think they ever changed the belts, tensioner, or pulleys. The belts were okay when I first replaced them. I still have them on my truck as spares. I think the reason my belts lasted so long is because my truck has always had an APU, so no need to idle.
  7. magoo68
    magoo68 Road Train Member
    3,393
    5,384
    Jun 11, 2011
    st malo mb canada
    I heard a guy on a maintenance program a few years back state that tensioners are designed to last the life of the belt.. according to him you should always change tensioner when belt needs replacement because it won’t last the life of the second belt..
  8. Rideandrepair
    17,198
    55,777
    Aug 8, 2015
    I didn’t change mine till well over a million.Ran new one for around 700 k. Currently been running original one for a year.Aside from tensioner weakening causing belts to jump. As long as bearing is good it’s good. They can last a long time. Also can replace bearings if tensioner part is still good. If you’re worried about it going out best to buy a new one and keep on board along with spare belt ( new or old) just in case. Run it till it goes bad. Worse case it seized up and breaks belt.
    PE_T Thanks this.
  9. Working2party
    608
    729
    Feb 10, 2018
    Kansas
    The issue that we have is with the tensioner Detroit puts on their DD15. I’m sure it works well on highway. But we’re only on pavement 10-20% of the time. The small gravel from country roads gets sucked up and imbedded in the belts, this make the tensioner work harder than its ment to and the pivot point and spring/ shock absorbers lock up. And we throw the accessory drive belt, usually in the middle of nowhere!!
    So in off highway applications, the Gates tensioner and belts are a better solution. Incase anyone is looking for the reason their DD15 is throwing belts randomly.
    D.Tibbitt, Rideandrepair and PE_T Thank this.
  10. A5¢
    A5¢ Medium Load Member
    389
    544
    Oct 30, 2017
    If you have any doubt about the tensioner and pulleys, remove the belt, spin the pulleys and tensioner and check for bearing play. All of those bearings are sealed, so no dirt can get in while the bearing is in good condition. If they are quiet and smooth, they should be good. If you change them just because of age, brand new bearings, right out of the box can fail. This is one of the MANY things that must be looked at on the pre and post trip inspection.
  11. Rideandrepair
    17,198
    55,777
    Aug 8, 2015
    There is a tool to check tension I’ve heard of Somewhere. Seems a 1/2” torque wrench could be used to compare old against new
    PE_T Thanks this.
