When loading/unloading should trailer air bags be dumped?
Discussion in 'Experienced Truckers' Advice' started by Florida Playboy, Apr 26, 2013.
  1. Florida Playboy
    Florida Playboy Road Train Member
    4,102
    6,621
    Dec 19, 2012
    Florida
    Like the title says when unloading or loading should the trailer air supply valve be dumped? What's the correct procedure?
  3. Saddletramp1200
    Saddletramp1200 Road Train Member
    2,111
    2,836
    Sep 4, 2011
    Houston Texas,USA
    Not really, it serves no purpose I know of.
  4. windsmith
    windsmith Road Train Member
    7,296
    6,031
    Sep 2, 2011
    NEPA
    I decide whether or not to dump by the height of the dock I'm backed up to. Sometimes I need air in the bags to get the trailer high enough that the ramp will be at a reasonable angle. When that is the case, leave the truck running at fast idle so that your air isn't depleted during loading / unloading. I don't think there's a requirement either way.
  5. Rugerfan
    Rugerfan Road Train Member
    7,010
    33,637
    May 3, 2011
    Redding,CA
    I run a flatbed and i rarely if ever set my trailer brakes. hope thats what your talking about anyways lol. but ive never had a problem with it. now most van haulers and reefer haulers ive seen always set them
    Big Duker Thanks this.
  6. pattyj
    pattyj Road Train Member
    22,474
    20,138
    Jul 19, 2008
    Sioux City,ia
    If you're attached to the trl while sitting at the dock then no you don't touch the air bag dump.But if you have to unhook,you first lower the landing gear,pull the fifthwheel pin,remove the glad hands and pigtail,then lower your airbags,wait a few seconds till they are completely deflated then slowly pull your trk out.Once your pulled out turn your airbag dump to inflate the bags then wait patiently for your trl.You won't need to lower your airbags when hooking up,I never do.
    mje Thanks this.
  7. Florida Playboy
    4,102
    6,621
    Dec 19, 2012
    Florida
    Someone told me it is hard on the airbags when inflated to have the forklift entering/leaving the trailer. So he said to always dump them. Sounds logical to me.
  8. pattyj
    22,474
    20,138
    Jul 19, 2008
    Sioux City,ia
    oh is that what the poster is asking,lol.
    mje and cetanediesel Thank this.
  9. Balakov100
    Balakov100 Road Train Member
    3,937
    2,635
    May 10, 2012
    Temple, TX
    Some trailers dump the Airpretty quickly with the Brakes Set. Others will take a while.
  10. cetanediesel
    cetanediesel Medium Load Member
    470
    186
    Mar 26, 2013
    Albany, NY
    What matters to the air bags themselves is, if they get overstretched. The shocks or straps usually keep them from overextending. If you are only unloading 2000lbs. at a time your not going to get much movement. But what I haul is usually a large piece of equipment. That moves 30,000lbs.+ off of the truck and trailer at once. The truck and trailer would pop up like popcorn if they weren't deflated. Also if you unload one side at a time, the bags dumped will help with leaning till your unloaded.
    gtmitch2 Thanks this.
  11. Crossroads
    Crossroads Light Load Member
    239
    236
    Feb 28, 2013
    Lumberton NC
    Normal and safest procedure to load would be to pull the red button to lock the trailer brakes while loading. Many trailers are loaded with no tractor attached and hence the air bags would not adjust in that situation anyway. The air bags will only raise a few inches and never seen a loading dock that could not accomodate that.
