When I brake, one air gauge is leaking.and THE OTHER ONE ISNT!! NEED HELP ASAP
Discussion in 'Trucks [ Eighteen Wheelers ]' started by sa_ali0794, Dec 25, 2019.
  1. sa_ali0794
    sa_ali0794 Bobtail Member
    Dec 25, 2019
    Minnesota
    So basically I have a 2000 freightliner fld. I have an Issue with my air gauges. When I press the brake, the right one is losing air. Idk why I have this problem. It’s a new one. Pls help. Also the warning lights for the air is popping up. I took it a garage and they don’t know what’s going on.
    MX127 and TravR1 Thank this.
  3. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    Well not surprised drivers don't know air brakes. But GARAGE in my world mean mechanic. OMG!!!!!!!!
    I don't know what designation is for the right gauge please read what it says on the gauge.
  4. SmallPackage
    5,273
    16,442
    Dec 20, 2019
    Marion Texas
    Is the leak coming out of the gauge and you can hear it in the dash or is it leaking somewhere in the system that the gauge monitors?
    How fast is air dropping?
    Chock tires so truck well not MOVE.
    Air up system
    Release park brake
    Let system air up the rest of the way up to 120
    Shut off truck and everything that makes noise around it.
    Put something on brake pedel that can hold it down.
    Walk around and under truck and trailer were the brake system is and listen for leak.
    Spray everything down with soapy water if you can.
    x1Heavy, jsnell and Hulld Thank this.
  5. Hulld
    Hulld Road Train Member
    2,882
    6,564
    Oct 19, 2015
    Upstate NY
    My best guess is you have a pretty big brake leak somewhere.
    When you step on the brake the air is leaking out and the the gauge drops and the low air warning light comes on.
    Shut the truck off push in the yellow and red air buttons (with a trailer attached) then have someone step on the brake pedal and you go around the truck and trailer and listen for the leak.
    x1Heavy, jsnell and SmallPackage Thank this.
  6. jsnell
    jsnell Light Load Member
    253
    343
    Apr 12, 2016
    Is one of your brake chambers leaking? Chalk wheels,. Release brakes,. Use a board to depress the brake pedal then walk around and listen for the leak. The other two posters beat me too it I ypet slow
  7. SmallPackage
    5,273
    16,442
    Dec 20, 2019
    Marion Texas
    I’m worried about op not knowing the basic air brake test. But as far as mechanic he may have in his panic taken it in to a car type shop that doesn’t know anything about airbrakes or trucks. So that is excusable.
    x1Heavy and Snailexpress Thank this.
  8. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    I cannot stand seeing truckers say they are not provided knowledge about air braking. Right gauge? Eh I could guess secondary, that would fall first followed by Primary but it will be maybe a brake chamber or something else.
    I don't know enough to attempt a opinion because the detail is lacking from OP.
    God help this industry if it constantly fails to teach methodology and theory of air braking etc.
    Numb and SmallPackage Thank this.
  9. Lowboy456
    Lowboy456 Light Load Member
    278
    127
    Mar 14, 2017
    Brake Chamber or Brake line sir!
    Rarely it will be a brake line to the brake chamber. You can change half the brake chamber, all of it or just the pancake if the brake chamber is in good condition. Just have to find which one is leaking as suggested in other posts. Not nearly as big a deal as it seems.
    x1Heavy Thanks this.
  10. dibstr
    dibstr Road Train Member
    1,308
    931
    Sep 10, 2010
    just a suggestion/question but why not push one button in at a time and know if it’s the tractor or trailer(use trolly)?
    starmac, Hulld and x1Heavy Thank this.
  11. x1Heavy
    34,017
    42,129
    Mar 5, 2016
    OP stated that he recieved no teaching from anyone regarding brake systems in 18 wheelers. So the buttons might as well be bright colored doodats that say lets go.
    dibstr Thanks this.
