When do you use liftable steer axles?
Discussion in 'Flatbed Trucking Forum' started by Lindsay2367, Jun 20, 2016.
  1. Lindsay2367
    Lindsay2367 Bobtail Member
    5
    Hi all!
    I'm trying to figure out on what trailers exactly would you use steering axles. I'm stumped. Is it logging only? Do dry vans ever use them? Do tankers?
    Are there regulations in the US that require the use of a steering axle ever?
  3. w.h.o
    w.h.o Road Train Member
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    ? Are you from Europe? We're it's common for most truck with steering trailer axles?
    The only steering axle I heard of, is heavy haulers with multi axle.
    Unless your not talking about that....because I don't even know what
    ....we are talking about... ^_^
    Dominick253 Thanks this.
  4. street beater
    street beater Road Train Member
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    I almost said i use mine most every day, aside from the days when my route is a straight line from my parking spot to drop site....
    Dominick253 and MidWest_MacDaddy Thank this.
  5. Dave_in_AZ
    369,691
    Fire engine hook & ladder?
  6. haulhand
    haulhand Road Train Member
    Are you talking about steerable lift axles?? The only time you see them on trailers is if they are running in the west where they get more weight than 80k. The all them maxi trailers and they put them on reefers and dry vans along with flats. They are used mainly in WA, OR, ID, UT, ND , MT, SD, and CO.
  7. Lindsay2367
    5
    Thanks everyone for the help!
    I am not from Europe, are they common there? I know they are more common in Canada I think due to regulations...
    to haulhand - thank you that is really helpful! I am referring to steer lift axles, but my question then is do steer axles exist that aren't lift?
  8. haulhand
    Sure I have a couple boosters that have dual tired steerables that don't lift. You have to have some way to lock a steerable axle straight when you back or else they go all wonky that's why most lift.
  9. Jumbo
    Jumbo Road Train Member
    3,669
    7,389
    Sep 4, 2009
    Appleton, Wisconsin
    They are used a lot more in Canada now after they passed the law phasing out non steerable lift axels.
  10. passingthru69
    Non lift steerable axles like Haulhand said can cause way to many issues in the backing of units, plus axle down when mty and wet or icy roads don't play well together either
    lester Thanks this.
  11. TripleSix
    127,940
    Steerable trailer axles dont normally lift. When do they require them? I dont know for certain, but for some reason, I remember it being required on a permit for loads over 150 ft (superload rules applied).
    FYI, every state has its own osow regs. They normally wont think much qbout the 10 wides. 12 starts getting strict. 14 wide, youre seeing mostly 2 lane.
    17 wide, 17 tall, 150+ long, 180000lbs normally will knock a load into the superload territory. Bid accordingly, otherwise youre gonna lose your arse.
